ArduPilot Purple + Skywalker X8 + FPV = Summer Loving
So I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the  router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
Comment by ggtronic on July 16, 2012 at 8:53pm
subscribe...X8 actual built...APM2+airspeed on its way... very little experience with APM1+bixler...really appreciate the PID sharing ! will fly it in FPV mode+EZuhf wich downlink actual GPS course live on GoogleEarth...
Comment by Hai Tran on July 17, 2012 at 8:29pm
Here's my retractable launch hook for my X8.
Unlike the Zephyr you don't have any thing to stop the launch hook getting damaged on landing, so I made it retractable using a spare Parkzone retract.
Comment by Hai Tran on July 19, 2012 at 6:49am
Ok, the launch hook was strong enough, however the 10m blue bungee managed to move the X8 2 metres and stopped on the ground.
Need 2 or 3 x bungees.
Hand launch was a success, and to my surprise had to dial my dual rates up mid flight from 50% to 100%.  Unlike the ZII, the X8 is slow and uses much more throws.
Comment by Toby Mills on July 19, 2012 at 2:33pm
Glad to here it went well.
Has anyone made any improvements on the PID's posted?
Comment by Toby Mills on July 20, 2012 at 6:41pm
I made an excellent discovery with the X8.
an iPhone4 fits perfectly in the nose tray at the front. Just carve out a small hole for the lens and you can do this....
http://www.hypr3d.com/models/4fe6981b50656b0001000043
Comment by Toby Mills on July 20, 2012 at 6:44pm
Comment by Alexandre Moreno Richwin Ferreir on July 20, 2012 at 6:53pm
Great results Toby,
i placed a Canon in the front too, the circle size is exactly the same of the lens.
The IPhone handles well with the focus?
Curiosity, what was the altitude above ground in that last link?
Comment by Toby Mills on July 20, 2012 at 6:56pm
focus is fine so long as you keep the speed down.
ummm - quite high :)
Comment by Hai Tran on July 28, 2012 at 7:45am
I need some help with my APM X8 please.  R/C controls operate the elevons correctly in Manual and Stabilise.
Stabilise operates the elevons in the correct directions.  Pitch stabilisation works perfect with full control deflection, but roll stabilisation is too slow because the elevons are only deflecting up but not down for roll stabilisation
When you roll the plane left, the APM commands right roll, which mean the right elevon goes up, which is correct, but the left elevon only travels down to neutral position, it doesn't go down all the way like when you move the R/C  stick to roll right.
Comment by JeffBetts_KK4MTC on July 28, 2012 at 4:43pm
I'm just getting started with my build and wonder how y'all have dealt with the ailerons. I'm thinking of cutting them out completely, sheeting on the bottom with 3/32 basswood, installing some Robart hinges instead of taping them.  The foam ailerons seem to be too flexible to work well with such a large plane w/o the reinforcement. The foam also seems too stiff for the aileron to move as far as it needs, unless the ailerons are dis-joined from the wing. Just curious what others have tried and what seems to work best.
Comment
