New 3D Robotics product: u-blox LEA-6H GPS
Hi everyone! I'm very happy to announce our new u-blox based GPS board. The development teams and 3D Robotics have been working on this GPS unit for some time, and we have seen very good results on ArduPlane, ArduCopter and ArduRover. The Sparkfun AVC and the Quadcopter Rodeo were excellent opportunities to observe this GPS in action, and it helped Team Overhead win first place at AVC.
The device is pretty straight-forward. It has active circuitry for the ceramic patch antenna, rechargeable backup battery for warm starts, and I2C EEPROM for configuration storage. The units will ship pre-configured for ArduPilot Mega use, and the configuration file is available in the repository if needed.
Features and Specifications:
  • ublox LEA-6H module
  • 5Hz max. update rate, configured for 4Hz for APM
  • 25 x 25 x 4 mm ceramic patch antenna
  • LNA and SAW filter
  • rechargeable 3V lithium backup battery
  • low noise 3.3V regulator
  • I2C EEPROM for configuration storage
  • power and fix indicator LEDs
  • ArduPilot Mega compatible 6-pin JST connector
  • exposed RX, TX, 5V and GND pads
  • 38 x 38 x 8.5 mm total size
  • 16.8 g weight
It's on sale now, price is $75.99 USD. It starts shipping on Monday, July 9th.
Design files and links to the board's main component data sheets can be found in the product listing.
We look forward to hearing your feedback!
Tags: 3D Robotics, 3DR, ArduCopter, ArduPilot Mega, ArduPlane, ArduRover, GPS
Comment by Chris Anderson on July 6, 2012 at 12:29pm
Jonathan: all of the DIYD videos from the Sparkfun AVC (planes, rovers and copters) are using the new GPS.
Comment by Jonathan M on July 6, 2012 at 12:56pm
Thanks, Chris.  Link?  Tried searching but I just found a promo video.  Thanks
Comment by Chris Anderson on July 6, 2012 at 1:01pm
There are a bunch here, but here's one
Comment by Marco Robustini on July 7, 2012 at 4:40am
Jonathan, all my videos of beta/alpha/release 2.6 are created using U-Blox GPS prototype (LEA-6M, not 6H):
http://www.youtube.com/watch?v=B0ET5P1HkYc&list=UUPcCCiqkWYZmvxVgHhDZDHA&index=1&feature=plcp
http://www.youtube.com/watch?list=UUPcCCiqkWYZmvxVgHhDZDHA&v=wj...
Comment by Greg on July 7, 2012 at 6:41am
Does anyone know or has tested if the new 3DR GPS LEA-6 will work with the Remzibi OSD sold in the 3DR store? I see this OSD is listed as not supported with APM2 so I am thinking no on my GPS question.
Comment by Ronald Chinn on July 7, 2012 at 6:19pm
If you look at the datasheets for either the MTK 3329 or this Ublox LEA-6 they list position accuracy about the same; less that 3meters. So, for those of you that have used both: Can you put it in simpler terms? Just how much more accurate is this Ublox?  As an example...I've got a GPS from Parallax  and I'm lucky if it's accuracy is (about)  +/- 60 feet (it's an older unit)... Is this new Ublox really as the datasheet says, down to about 10-11 feet?
Admin
Comment by Thomas J Coyle III on July 7, 2012 at 6:42pm
@Ronald,
I think that Chris Anderson stated that he was subjectively getting around 30cm accuracy while running a course with his rover over a 25 minute period. The 30cm accuracy was the variance of the rover outside of the intended course.
TCIII
Comment by Randy on July 7, 2012 at 8:36pm
I think that 3m position accuracy is good first indicator of how good the GPS is..of course it'll tell you how far the position the GPS is reporting is from it's actual position..but more important to the performance of loiter is the accuracy of speed information.  Again, sorry, it's a bit anecdotal and lacking in hard data to back it up but this seems much better on the ublox.
Comment by Hans Jakob Bosshard on July 8, 2012 at 2:21pm
Is the ublox GPS also compatible with the APM 1 in place of the MTK GPS? Is there a need for a special configuration action?
Comment by Chris Anderson on July 8, 2012 at 2:53pm
Hans: Yes. No configuration needed if you're using the latest ArduPlane/ArduCopter code. It will be autodetected and set up automatically.
Comment
