Here a video of an autonomous flight with a Maxi Swift flying wing fully piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board.This is a porting of the ArduPlane v2 (v2.4+v2.5) firmware and special addons and improvements for the AIOP board that I have added.
The wind was 15 km/h gusting 22 km/h. The flight was very stable in spite of the gusty wind conditions.
Setup:
Flying Wing: Maxi Swift from MS Composite (1m40 wingspan)
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Rana, 110$US or 110 British pounds ?
Comment by Harry on August 16, 2012 at 10:06pm Jean-Louis, vous faites un travail brilliant. Beaucoup awesome.
@Rana - is this NEO-6M really working as stated? I don't see its antenna on the board.
Thanks Jean-Louis!
I think I found the cheapest way to get it:
Crius CN-06 GPS Receiver Module $26.51
CRIUS ALL IN ONE PRO v1.0 Multi-Copter Flight Control Board Support...
It is cheaper than Rana suggested, except that this AIOP board doesn't say "Support MegaPirateNG and MultiWii". Pictures are the same. So is it safe to buy?
Comment by Rana on August 17, 2012 at 8:50am YureZzZ, I have not tested NEO-6M GPS but It should work as it is tested by JLN.
I was following up the development at MegaPirate Next Generation, so purchased CRIUS ALL IN ONE PRO v1.0 board quite early. Since microcontroller is same (ATMEGA2560), people at MegaPirateNG are continuously porting the latest code developed by the Arducopter Team, to that board.
Comment by Austin H on August 17, 2012 at 10:20am
amazing work Jean !
would it be possible for you to post the modifications you did to the board
glad to see other boards being discussed here
Comment by Rana on August 17, 2012 at 9:44pm Excellent JLN !
58 members
1355 members
207 members
52 members
Powered by
