I've been developing a hexacopter with a new code, using the Arducopter libreries.
As a testing work bench, I've been using a platform like the pictures above.
In this way you can test it safety without any accident or crashes with material loss.
The hexacopter can move with in the 3 axis and have 3 potenciometers to know the exactly position.
Here you can see it working in the video:
min,
0.00 description.
0.33 Yaw control.
1.01 Pitch & roll control.
2.05 Vibrations.
I dont know what will be the differents between the simulator and the real flight. have anyone any suggestion or idea??
During my tests i've found many vibrations while it is working at high speed... I hope it will disappear in the air. does anyone know why??
I'm using the ArduPilotMega 1.4 board.
While testing i have found a lot of noise with the roll Axis. Here are the graphics of a test.
(legend: red=accel, black=gyro, cyan and gren=motors speed)
Ptich axis:
Roll axis:
Due to roll gyro has a strange behaviour I recorded the data without any moving in the starting position without motors, here are the plots:
Maeby my gyroscope is not correct... ( bought it in September). I dont understand why the accel.y correspond with gyro.x and viceversa... and gyro.y has opposite sign than accel.x
my code, mainly is:
[declarations]
[read radio]
imu.update();
accel = imu.get_accel();
gyro = imu.get_gyro();
pitch = accel.y;
roll = accel.x;
giroPitch= gyro.x;
giroRoll = gyro.y;
[discrete filters for accel]
pitchSum +=errorPitch; //integral
rollSum += errorRoll; //integral
errorPitch=yref-pitchFilter;
errorRoll=xref-rollFilter;
//FRONT RED
valor[1] = throttle + 1.0* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum);
valor[5] = throttle + 0.5* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum) -0.866* (KpP*errorPitch +KdP*giroPitchFilter + KiP*pitchSum);
valor[4] = throttle + 0.5* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum) +0.866* (KpP*errorPitch +KdP*giroPitchFilter + KiP*pitchSum);
//BACK BLACK
valor[2] = throttle - 1.0* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum);
valor[3] = throttle - 0.5* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum) -0.866* (KpP*errorPitch +KdP*giroPitchFilter + KiP*pitchSum);
valor[6] = throttle - 0.5* (KpR*errorRoll - KdR*giroRollFilter + KiR*rollSum) +0.866* (KpP*errorPitch +KdP*giroPitchFilter + KiP*pitchSum);
// CONTROL DEL YAW
valor[1] +=kyaw*yaw;
valor[3] +=kyaw*yaw;
valor[6] +=kyaw*yaw;
valor[2] -=kyaw*yaw;
valor[4] -=kyaw*yaw;
valor[5] -=kyaw*yaw;
[constrain]
for(int8_t i=1;i<=6;i++){
APM_RC.OutputCh(i,0 ); //valor[i]
[sent data]
Any commentary is welcome!!! :)
Regards. Alberto.
Original post: www.dieBotReise.blogspot.com
Comment by Michael Pursifull on August 20, 2012 at 11:11pm Maybe add:
* extendable mast pole so it can freely move up/down by 1m
* cross frame from CNC machine to allow the entire mount to move in X and Y freely by 1m in 2D
Make these low friction and it will be better able to test your copters.
I like your set-up. I don't have anything so sophisticated but I use a rotating plate for testing yaw...the issue I find is that even though it's got ball-bearings and has relatively low friction the extra mass of the plate and the extra friction only make it a rough approximation for real life test. So it's good enough to find big problems (for example which motor is much weaker than the others) but it doesn't act too much like it does once in the air.
Comment by Michael Pursifull on August 21, 2012 at 2:09am I agree, of course.... I use a bit of kite string which I run up through two pulleys to the ceiling then across the room, where it attaches to a medium sized wrench to act as a stop so the 'copter does not fall all the way to the ground, and the props can clear the ground (and walls) no matter what orientation. Even the tiny resistance of the string changes the flight such that it creates problems ... but it's better than free-flight for risqué testing... well, cheaper, anyways.
Very interesting. It has many of the elements I considered and sketched out.
My solution was much simpler in a tethered weight and practice with FMS and RealFlight.
Keep thinking and testing. Bravo!
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.5 members
1282 members
183 members
674 members
116 members
Powered by
