NEW APM 2.5 Pin out and Wire Diagram And Camera Gimble explanation
Hey guys i recently got the APM 2.5, when looking at the pins, I saw A0 - A11 Pins werent being used and i did not know what they were for so i was googling and found a PDF that stated
A0- Sonar/ Ultrasonic A1- Voltage Sensor – Attopilot
A2-Current Sensor – Attopilot
A3- Optical Flow Sensor
A4-Motor LED
A5-Motor LED / Buzzer
A6-Motor LED
A7-Motor LED
A8-Motor LED / Analogue RSSI
A9-Camera Shutterhttp://speedtester.bsnl.co.in/
A10-Camera Roll
Link to Gimble explanation in google
http://code.google.com/p/arducopter/wiki/AC2_Camera
So After researching for some time, I have found that for a camera gimble A10 is roll and A11 is pich but there was no explanation of were Pan is connected (YAW).So I i dug some more and found some consensus to the following :
Currently Mission Planner shows that we have 3 axis so would be good to update that. I suspect (haven't check the code) that PAN goes to A9 but that is just a guess.
Anyway, I lack one wiki page on those extra outputs, what can be connected to them. So we have A11, A10 (and A9?) for gimbal, A1 and A2 for AttoPilot? current/voltage sensor:.
So after my post was denied several times as being " a request for assistance" let me rephrase, What is your guys experience, have you tried A9  and it worked or not, what other solutions have you tried?
Here is more info: http://copter.ardupilot.com/wiki/camera-mount/
Admin
Comment by Morli on May 19, 2013 at 1:46am
Good Documentation.  Tnx for sharing
Comment by Craig Doyle on May 19, 2013 at 3:28am
There is certainly a need for more explanation for these pins
Not sure what "motor LED" means for instance
Lots of potential but don't know how to tap it
Thanks for the post
Comment by mohd fitri on May 19, 2013 at 5:29am
MIne not function for the camera Roll and Pitch  gimble function on any Pin
Comment by Jared Reabow on May 19, 2013 at 6:32am
you enabled the gimble in the missionplanner?
Comment by Bill Bonney on May 19, 2013 at 7:15am
A9 is PWM out you can use it for anything that needs PWM out. You can configure in mission planner or advanced parameters page
Comment by Sebastian Pometti on May 19, 2013 at 7:18am
If you got the plastic case, dont trust in the numbers printed on this because they dont match with the pins.
Comment by Bill Bonney on May 19, 2013 at 7:18am
jared: the diagram is labeling the SPI port as A9-A11, which is wrong. Also note A9-11 can either be PWM out 9-11 or analog in see http://code.google.com/p/arducopter/wiki/SolderJumpers to see how they can be changed
Comment by Earl on May 19, 2013 at 8:39am
In mission planner you can set the battery voltage and current to pins A0-A13. Where is A12 and A13 ?
Earl
Comment by Bill Bonney on May 19, 2013 at 8:45am
@earl: A12 & A13 are routed to the Power Management port for the power module.
Comment by Bill Bonney on May 20, 2013 at 7:44am
@stone1295: Mike A12 is not under the S+- in the diagram. That's the SPI port.
Comment
