3DR Solo now with RTK !
3689707799?profile=original
First of all, Happy New Year Community ... We wish you a Happy flight year !
Good news for Solo owners, we just released 2 versions of Solo GPS to replace your factory GNSS. One with u-blox NEO-M8N or NEO-M8T and one with u-blox NEO-M8P
3689707747?profile=original
3DR SOLO RTK GPS (NEO-M8P)
The only RTK GPS based on u-blox NEO-M8P for 3DR SOLO
Key features:
  • Centimeter‑level GNSS positioning for mass market, based on U-Blox M8P
  • Integrated Real Time Kinematics (RTK) for fast time‑to‑market
  • Smallest, lightest, and best energy‑efficient RTK module
  • Antenna patch
  • Power filter, ESD protection, overvoltage protection
  • Receiver type: 72-channel GPS L1 , GLONASS L1, BeiDou B1, GALILEO E1
  • Nav. update rate: up to 8 Hz
  • Position accuracy: 2.5 cm
  • Connectors: USB micro, Clik-Mate
  • Weight: 16g
You can use our new RTK Base Station based on u-blox NEO-M8P with this product http://drotek.io/2i3NcdW
3689707875?profile=original
3DR SOLO GPS (NEO-M8N or NEO-M8T)
Upgrade your solo with the last u-blox module for 3DR SOLO
Key features:
  • Ublox NEO-M8N or NEO-M8T
  • Plug and play on 3DR SOLO
  • Antenna patch
  • Receiver type: 72-channel GPS, GLONASS, BeiDou, QZSS, SBAS and Galileo
  • Weight: 16g
Products will be available for shipping from January 20st. Due to high demand, preorder your GPS to ensure delivery from this date.
  • You have should received a reply. Let me know please.
  • Hello I am trying to contact but we don´t get any answer from your contact form
    Can you give me a contact information so we can ask some questions about your products before order?
  • i cant find anyone using this.   has anyone seeing posts with the neo.m8t and the 3dr solo ?    seems like a great RTK or PPK solution.  scoured high and low. nothing but a few promos from the company w nothing involving the 3dr solo.  currently w mavic pro.  thinking phantom 4 pro and GCP investment.  but cant remove this as an option yet !!
  • Drotek :can make some video in YouTube ,how to install and upgrade, I think so many solo user want know that and buy you prouduct! I planning to buy it! thx thank you design product to solo!
  • M8P performance is good, in 4-5 min you can achieve centimeter level locks, which is good compared to other products on the market. There are built-in integrity functions so the output is rock solid. Additionnally u-blox constantly improves firmware to improve lock/precision/features. Documentation coming!
  • Interesting...
    Can the setup be used instead for Post- Processing?
  • I would be good to see some documentation on which firmware to download and flash SOLO firmware with the new firmware that support the new Drotek RTK. I like see Wiki or documentation how to install a new firmware from Drokek (if possible) for SOLO with Dritek RTK. It seems that Mission Planner has support for RTK GPS lately.
  • Sounds interesting!
    So how u-blox' rtk in M8P shows itself? Did you test it?
  • @Jonathan @Artem
    The easiest way to send the corrections without any additional hardware modification is to use built-in Wifi and Mission Planner (with base station connected to it)) with the "Inject GPS" function. It will send corrections over the existing MAVlink.
  • Also, is there a way to send correction via the same mavlink? it would be nice to run rtk client on FC or a companion to utilize the existing link and have rtk base connected to the controller, while at the same time using a regular GPS with good antenna on the aircraft.
