This is the picture of me flying it, it flew very nice by the way, and I also add it a better landing gear for begginers and some propeller protectors to make it easy to manage.
R. D. Starwalt yes you are right andJohn Maffetone I also mark a straight line down the length of the tube, this is how i manage dimensions, if you want i can send you the Solidworks file if you want.
hi abhraham,
can i import the design in "design spark" ?? i want to build a V Tail Quad from 3/4" PVC and looking for as many inputs as possible.
your help in this matter will be very valuable...
R. D. Starwalt yes you are right and John Maffetone I also mark a straight line down the length of the tube, this is how i manage dimensions, if you want i can send you the Solidworks file if you want.
Interesting idea.
How did you manage to keep the motors on plane with the main body plates?
I would guess you could simply slide the pipe into the body space and mark/drill the holes. Then continue the same body plane out to the motor holes.
Another example of using what is available.
-=Doug
