MR60
433 Mhz antenna comparison - DIY & standard stock models
3689626007?profile=original
Within AirbotServices.com, all of our professionally built drones integrate a live telemetry link, outside of the main transmitter frequency band. We consider it to be a critical safety element that should be enforced in future European regulations for commercial drone activities. It is a must have. Why, you may ask ?
The current relative lack of reliability inherent to complex electronics and software modules composing a drone (although it may integrate redundancy) will sooner or later inevitably translates in "gremlins" during flight (a priori unexplained bugs) and/or eventually flyaways (uncontrolled drones).
Telemetry provides multiple safety functions:
-A safety functionality by monitoring real time critical elements that should be taken into account by the pilot (battery level typically)
-A safety functionality by sending real-time positionning (GPS) data on the ground station which can be used to find your drone that flew away;
-A debugging functionality by providing real-time to the ground the values of internal parameters (and therefore helps finding out why there is an uncontrollable behaviour);
-A logging functionality (Tlogs);
-An out-of-band communication outside the Radio transmitter band (it the 2.4ghz fails, the telemetry link might save you); not only to receive flight parameters on the ground but also to send  commands.
433Mhz is the frequency of choice for telemetry as it provides the best range & penetration capacity through objects and walls versus higher frequencies (i.e. 900 Mhz or higher).
In Europe the maximum power allowed for using 433Mhz band, for other uses than amateur radio (for which an amateur radio license allows you to use hundreds or thousands of watts), is 10 milliwatts. This band is used for house alarm systems, remote controlled devices, etc.
Such a small power allowance makes it critical to optimize antenna designs on our drones, to maximize the range.
On the test bench : 4 different 433Mhz antenna models:
We will compare hereunder various 433Mhz antenna models, some are commercial stock models, others are DIY models based on best practices, among which excellent build advices provided on this diydrones blog:
http://diydrones.com/profiles/blogs/dipole-style-antenna-for-433mhz?id=705844%3ABlogPost%3A1674324
  • 3DRobotics model:
The standard 3DR duck telemetry antenna such as shown here
3689626041?profile=originalis a 2Db compact sleeved dipole. It is sold with the 3DR telemetry kit.
  • Nagoya 144/433 Mhz model :
3689625865?profile=original
Nagoya is famous for building excellent antennas. This is their telescope antenna, model NA-773.
  • AirbotServices' sleeved dipole model:
This is a 433Mhz model built by AirbotServices, designed by Joe ("Nampilot") as described in the blog link above,
3689626051?profile=originalIt is made of 100% copper. Contrarily to simple dipoles where the two active elements have the same length and are fed in the middle (wich requires a balun to balance it to 50 ohms), this dipole consists of a longer top copper wire and a shorter copper tube which acts as a balun at the same time. The resulting antenna is not only perfectly tuned for 433Mhz, it is also 50ohms balanced without an additional balun.
A RG316 cable feeds this antenna.
  • AirbotServices simple (standard dipole) model:
3689626063?profile=originalThis is the classical dipole with servo wire and a RG316 feeding coax. We added a ferrite choke as a balun. The center is reinforced with balsa to maintain 90 degree angle between the active elements and the feeding coax.
Test method and results:
We use the RF explorer spectrum analyser as our test equipment. Rather than using its small integrated LCD screen, we used the windows PC client software, connected by USB to the RF explorer.
The test signal was picked purely and simply in the ambiant "433Mhz band" signals. At the moment of the test, a particular peak signal was found at about 424-426Mhz. It is not an issue to measure aside the pure 433Mhz frequency as the telemetry device uses frequency hopping between 414Mhz and 454 Mhz.
So each tested antenna were screwed one after the other on RF explorer and we waited for a stabilization period. After which the signal DB levels were measured as follows:
The 3DR duck style Model:
3689626111?profile=originalThe 3DR duck style antenna measures a -78Db signal level.
The Nagoya antenna model:
3689626076?profile=originalThe Nagoya antenna measures a -69Db signal level.
The AirbotServices sleeved dipole model:
3689625882?profile=originalThe AirbotServices sleeved dipole model measures a -69.5 Db signal level.
The AirbotServices standard dipole model:
3689626157?profile=original
The AirbotServices standard dipole model measures a -73.5 Db signal level.
Conclusions:
-The base 3DR duck model provides the least performance as we could expect, fixing an arbitrary base a reference level of -78Db
-Both the Nagoya and AirbotServices sleeved dipole provide the best performance, improving the measured signal by 9Db relatively to the base 3DR model.
-The standard dipole model lays in between with -73.5Db, which  is still 5Db better than the 3DR model. It was also noticed during the measurements that this dipole is quite sensitive to polarization : a difference of 5Db could be measured by rotating the polarization. This sensitivity was not noticed that much with AirbotServices sleeved dipole.
There you have it, our quick telemetry 433Mhz antennas test bench.
Cheers,
Hugues
  • MR60
    @Jake, surely lots of people are breaking the power limits. It is practically impossible to measure since it dépends on so many factors.
    @Fnoop, dBm means DB milliwatts, or in other words the reference unit being milliwatts. So yes, i was measuring very low power levels (max 10 milliwatts)
  • @Hughes - Thanks for radio signals 101 :)  I looked up a bit further and found this entry which explains dBm better and that dB is a dimensionless unit.  You refer to dB a lot, but the graphs refer to dBm - are your figures all dBm?  If so they're very low power, so how far away from the transmitter was the measuring unit, or were you transmitting on very low power?  It's interesting that there's such a big difference in signal level from the different antennas - I'll definitely invest in a couple of the above now.
    @Jake - Not sure it's a very good idea to encourage people here to break the law.  These are the restrictions in the Europe like it or not, and if everyone starts flouting the law then we get the wild west and nothing will work at all, even if it sucks for the little people like us.  Different countries appear to have slightly different laws, and at least the 3dr radios allow you to easily change the power and duty cycle.  What is useful though is for open discussions like this to establish how we can get the best possible range and reliability out of the existing rules.
    Oh, and ps - Europe has been driving on the left for thousands of years before the modern US ever existed :)
  • I got sidetracked and forgot to thank you for a great article with useful information.  We need more experiments and discussions like these.
    I still predict trouble on the 433 band though.  I think there's a lot of people illegally transmitting on 433 in the US, and sooner or later it's going to cause problems.
    In fact, I think a lot of wireless transmission is done illegally here, and probably over the pond too.  Nobody seems interested in enforcing it, and even if they did it would be very difficult as a practical matter.
  • MR60
    Hi Jake, I can only agree with what you're saying about our stupid EU governments. This is why with so small emitting power I try to optimize my antenna designs...
  • You're telling me all you have is 10mW across 1.75 Mhz?
    I think you need to look into that more.  Essentially your gov. provents you from transmitting anything at all?  That just doesn't seem right.
    If that's the case then you guys need to look for another solution.  Lobby your government, riot, or just do what you're going to do anyways.  I'm not sure why you would obey the law when 99% of the gear out there shipping by the 100,000 units is just flaunting the law.  Especially when they're not doing anything about any of that gear.
    They really can't expect you to obey their oddball BS laws when they're not following the standards of radio inventors and the countries that are producing all the gear.
    It's like if we invented the automobile and made the laws on how to drive and then out of spite you guys just decide to do everything in reverse!  Oh, wait that actually happened.
    In any case, 433 looks better than nothing, but that is short-sighted.  You have essentially 2 non-overlapping channels.  That's not going to work when you have 10 people trying to use them.  It will quickly break down to where you're getting a high error rate due to so many collisions.
  • MR60
    Anyway in Europe we do not have a choice, it is 433mhz or nothing. APM telemetry bandwidth is totally fine with what the 433mhz band offers. No need for large bandwidth, this is not video.
  • It's unfortunate that some countries have squandered their ISM bandwidth by selling it off to licensed users.
    However, that doesn't really address the problem of the 433 band being tiny and crowded.  You've got lots of very cheap electronics like garage door openers transmitting on that band.
    And you've got a lot of HAM radio users licensed to transmit very high power on that band (70 cm band).
    The 433 band has 1.74 Mhz, compared to 26 Mhz in the 900 band.
    There's only 69 channels in the 433 band, compared to 1040 in the 900 band.
    GSM-900 uses 890-915 Mhz, so you're still left with 13 Mhz in the 900 band.  That's still over 7 times the 433 bandwidth!
    Our FHSS telemetry systems, like the 3DR radio, default to using 30 channels on the 433 band.  So you can only have 2 radio pairs operating in any given area without overlapping.  Take out a few channels for the many other users that might be around (and often transmitting much higher power), and you can probably start to see the problem.
    Add to that the fact that you might run into an amature TV transmitter wiping out the entire 433 band.  An ATV operator transmitting on channel 59 will utterly wipe out 432-438 MHz.  And they can and do often legally transmit 100's of watts of power.  With their intermittent transmission schedules I'm surprised there haven't been many cases of these 433 RC/telemetry systems crashing.
  • MR60
    @Jake, the best frequency band obviously depends on the country you live in. Except in the US, most countries have their GSM frequency in the 900 MHz band. The most illegal and crowded frequency band to use....Therefore 433mhz.
  • 433Mhz is the frequency of choice for telemetry
    433 is somewhat popular currently, mainly because we don't have very good choices in telemetry radios.  The 900 band is a much better choice because of the less crowded band and good compromise between antenna size and range.
    In the US we can legally transmit up to 4W on the almost completely vacant 900Mhz band.  Something like the RFD900 is far superior to anything available in the 433 band.
    http://rfdesign.com.au/index.php/rfd900
    The 433 band is also doomed by the miniscule bandwidth available.  It will quickly become saturated and completely unusable for anything required to be reliable.  You just can't build a future based on a couple Mhz of bandwidth.
  • MR60
    @Dom, "db" is a measurement metric used in physics for various phenomenons : acoustic, antenna gains, etc.
    "db" is the acronym of Decibel. A DB does not have a unit because it is the relative measurement versus a reference measurement (therefore units cancel each other).
    The mathematical definition is X db = 10 x Log(Measured parameter /Reference parameter). The parameter in the radio/antenna world is the gain of an antenna. The reference gain is the gain of an ideal dipole antenna. We speak then of "dbi" (i means ideal).
    So basically what you should take away is that a Db measurement is a reltaive measurement versus a reference. It does not give you any absolute measurement value with a certain unit (i.e. watts, meters, kilograms, etc).
    The reference is dependent and chosen in function of what you 'd like to measure : an antenna gain, a sound level, etc.
    I do not know if this helps you a bit or confused you even more?
