Just stumbled upon this amazing board. Would be really interesting to use it for a quad project. What do you guys think??
http://wiki.ladyada.net/chumbyhackerboard
Comment by T.D. Gonzales on March 5, 2011 at 9:19am
Comment by geir on March 5, 2011 at 9:32am Its about 10x6cm, cant find any thing about weight. Its got an accelerometer, supports wifi might eaven be able to mount a camera on it :)
Low power, fanless CPU draws only 200 mA at 5V
Comment by pixhawk on March 5, 2011 at 9:46am If you want to do Linux onboard, I recommend the 20x58 mm Gumstix Overo with 720 MHz (and there is a version with 512 MB RAM). It weights 27g INCLUDING a machine vision camera (which is quite cheap for $75, usually cameras with the same sensor cost $200-$400).
Please note that most cameras out there sold with single board computers don't provide a global shutter, which results in tearing in the image. For more info, you might be interested in these pages:
http://pixhawk.ethz.ch/2010/11/11/gumstix-overo-camera/
http://pixhawk.ethz.ch/wiki/electronics/camera#rolling_shutter_effect
Comment by MarcS on March 5, 2011 at 11:25am Hi,
not sure if this board is really ideal for flying objects. The connections availible are missing some important ones.. (AD, more serial, PWM..) Just as the gumstix, only bigger...
Some time ago I met a guy who was building a quadrocopter based on a x86 Board (runnig WinXP...).
http://www.roboard.com/index.htm
Similar size but optimized for ground based robots...
But now they are building a smaller one, should be there soon:
http://robosavvy.com/forum/viewtopic.php?p=30235
Thats a lot of power in a small package!
Marc
Comment by pixhawk on March 5, 2011 at 11:36am Interesting board, however I think it will never be worth the overhead striving for a 1-board solution for an autopilot. Established systems such as APM provide a high level of testing and robustness (RC fallback, etc.), filters, controller code and a whole world of helpful features and all you need to do is to interface them via serial port (there is finished software for this, e.g. MAVCONN: https://github.com/pixhawk/mavconn). For the price of a specialized robotics board with a decent processor you get easily one of the industry-standard off-the-shelf Linux single board computers plus one of the standard/popular autopilots. Since we're doing heavy onboard computer vision at PIXHAWK we noticed its quite beneficial to not have autopilot and onboard computer coupled too closely - because we are switching back and forth between a 27g Gumstix Overo and a 220g Intel Core 2 DUO onboard computer, but keep the same autopilot hardware and controller code. This would be impossible with a specialized robotics board plus it would be way more expensive. And as the Intel i7 is now also available as industry PC, we can easily upgrade.
I'm not making a point against specialized robotics hardware, just consider what you get regarding software from an autopilot board and consider the costs for any low-volume robotics module.
Comment by Tim Michals on March 5, 2011 at 11:50am I agree trying to keep the design moulder... here is another small board http://www.linuxfordevices.com/c/a/News/Toradex-Xiilun-PC-and-Topaz...
One thing the E6xx has is HW encoders for video and two threading cores. I asked about power and there is no specs yet I would image around 10W for a 1.6G board.... It would be nice to have SATA access for storing large video files...
Aslo the beagleboard is nice, there is a wireless board coming out soon that will support soft AP... so now a phone, or any client 802.11g/n device can talk to it...
Also, looking at making a connector board for the pixhawk camera for the beagle board...
Comment by pixhawk on March 5, 2011 at 11:59am This might sound weird, but why would you prefer the BeagleBoard over the smaller alternatives like e.g. the Gumstix Overo (or similar OMAP3 credit-card sized PCs)? The processor is the same and the BeagleBoard is so much heavier and taller?
ATOM indeed draws about 9-12W, depending on the configuration. If power consumption and space is not super critical, I would however recommend an Intel Core 2 DUO: It draws 27W peak, but for image or signal processing our benchmarks (SIFT feature extraction, SURF feature extraction, KLT tracking) showed that the Intel Core 2 DUO at 1.86 GHz is about 6x-8x faster per core than an 1.6 GHz ATOM. And with a size of 95 x 95 mm, its less than twice as big (e.g. Kontron microETXExpress PC module).
Comment by Tim Michals on March 5, 2011 at 12:15pm Beagleboard vs gumstix
1. Price, the mx board is $149
2. The wireless module supports soft AP, gumstix does not
Comment by Piotr Esden-Tempski on March 5, 2011 at 12:48pm
Comment by Ethan Ferrell on March 5, 2011 at 4:51pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
57 members
24 members
1288 members
680 members
Powered by
