  • Ahmed, i am talking about delta wing with a friend but i am some doubts:
    Delta wing need reflex like zagi or other flywing ?
    How are the tests of you delta wing ? how many km it fly with one battery ?
    regards
  • Thanks for the comment the parachute is under the plane which fall out due to gravity in this case it is deployed 99% with success. If you are trying to eject it from upside it will cause trouble and success rate is low there is also a small drogue chute to help parachute deployed properly. Hope this help you.
  • Looks like a drogue chute? I am trying to get my parachute deployment working, can you please post how you are getting such nice results? Very nice plane!!!
    Thank you!
  • good efficiency! can you tell which prop are you using? thanks!
  • realy nice wing.
    i have 2 wings with motor in the front. Its realy much easy and secure to takeoff.
    In my specific job, i need motor in the rear because i land in inhospitable area and my fly wing not have parachute.
  • Airframe only is around 2700 grams and cruise at less than 200watts its low speed handling is very good and has low drag. Camera is under belly pod.
  • Nice, must be meant for high speeds due to lower aspect ratio. Can you provide weight and power specs?
  • will start production soon also will do foam model for it.
  • We have made a mold for it.
  • nice
