Hi all,
Maybe an idea for revision E of the 3DR Hexa?
After having played for some time with my 3DR Quad, I decided to make some changes. Actually, I wanted a hexa for more lifting power. And I was inspired by the guys from Team Blacksheep and their awesome FPV platforms. So I wanted a 'low-rise' Hexa with not too many stacked plates.
What to do? I bought a complete second 3DR Quad frame including motors, and when you add them together... you can build a Hexa AND you are left with some spare parts! 2 spare motors etc. which is great!
As you can see, it's really based on 2 Quad Base plates stuck together by an undermounted Quad arm/leg.
(OK, I had another extra black arm lying around). This also allows for perfect mounting of the small and lightweight HK Pan/Tilt GoPro camera gimbal.
Here's what it looks like, and below a test video (1:12mins) which was it's maiden voyage! I was a bit worried about stability, but it was amazingly stable (using APM 2.8.1)
Let me know what you think! As you can see, it's pretty slim!
Comment by Hasufel on February 17, 2013 at 7:07pm Very nice! Can you take a pic of underneath to show how you managed to stack the two bases? Thanks!
Comment by Carl La France on February 17, 2013 at 9:07pm Looks great! do the extra 2 motors shorten flight time significantly or did up up the battery size?
Comment by Stefan78 on February 18, 2013 at 3:27am
Comment by Stefan78 on February 18, 2013 at 3:32am @ Carl La France
Thanks! With my current battery (3S 3600 mAH) I used to get about 10 mins. of flying time (fully loaded with camera) and now it's about 8.30 mins which is more or less what I had expected. Now I would want some more flying time than this so I'm going to try and see what happens when I use two batteries (3600 + 3000 mAH).
Of course, it adds weight, but I notice that the 6 motors have more excess power than the Quad did (which also makes sense).
Curious to see what happens. It's a challenge to find out what the best performance ratio will be, flying time vs battery power and battery weight.
Comment by Stefan78 on February 18, 2013 at 3:37am @ Hasufel
The above image shows not the final setup of the copter. I still use a riser there so the cover plate at the back is raised so the the hexa is not yet as slim as in the final version. This is what is showing in the very first picture in the original post. You can see the top is flatter there.
Comment by Mark Böhm on February 18, 2013 at 4:32am Maybe it's possible to remove two of the legs of the landing gear? (to save some weight)
The copter looks great. Good job!
Comment by Stefan78 on February 18, 2013 at 5:19am @Mark Böhm: I'll give that a try. It should be able to support itself with just 4 pairs of legs (though I like the look with 6 pairs). Tradeoff between Looks and Performance. The legs a pretty light, but any weightreduction will help extend the flying time.
On a side note about looks: my wife keeps telling me that it doesn't look 'friendly' enough and that I should put something on it to make it look more friendly. Even thought I am not really considering that, because of the weight, I have no idea what that could be.
How to make your drone more friendly? Paint a smile on it?
Comment by Carl La France on February 18, 2013 at 7:54am When you try something different it is always a compromise and you work the new issues as they appear what I like about this web site people like yourself actually "Do Stuff ' . As for making your drone look more friendly
tell your wife" form follows function" maby one of those happy face stickers on the back of the camera (let your wife pick it out ) or some of those "big bug eyes on springs and a smile" or have everybody stand back and deliver some teddy bears to a child care center with it the women would love that Have a Great Day
Comment by Craig Fraser on February 18, 2013 at 10:31am Cool. I think longer "H-style" central platforms just has to be in the future. Space is our friend when there's lots of electronics, and close vertical stacking just doesn't cut it beyond a certain point.
For "looks", you might consider a longish light plastic, probably opaque, cover over your two central bases. This can weigh almost nothing since it's only for looks and not necessarily protection. Some prepared "deli" food comes in black plastic containers that would probably fit well. Or you could put a big ribbon/bow on it...
Comment by Craig Fraser on February 18, 2013 at 5:20pm Here is sort of what I meant, except it's round and much stronger (salad came in it, still "free"). It is large enough that it should just cover your two hubs.
[I was wanting to use two of these at one time, one on the bottom too, but didn't work at it long enough to figure out a secure way to attach the bottom one so I could get at the main battery easily. The secondary reason (after protection) I like to cover my electronics is they get filled with bits of grass and dirt (yup, I'm that good!) and it takes me ages to clean them off. Sorry for the surrounding mess I didn't clean up first...]
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.683 members
24 members
184 members
51 members
1288 members
Powered by
