UPDATE : I have discarded the Zephyr V70 option due to input from you guys . I am now torn between these :
Hi Guys,
I had been checking out the Zephyr v70 V-Tail Glider as an APM platform, but am not sure if all the GPS and telemetry, most importantly the APM 1 board with Oilpan will fit in it.
I am planning on running it on a 3S 2200mAh LiPo, so I get some extra space there, but the APM seems awfully large and if it fits, it will be a tight fit with the R/C Rx.
If someone has the Zephyr, it being such a popular glider, I would like to know their opinion.
Another question - does the current ArduPlane code support V-Tail mixing? Its probably there, but needs to be enabled in the code manually???
Product Page: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=...
Kabir
Comment by Christiaan van Vollenstee on August 29, 2012 at 7:04am Hello,
Be safe and buy the bixler 1, its perfect for what you want to do.
Comment by Paul Marsh on August 29, 2012 at 8:31am Hi Mohammed,
This is a sexy looking aircraft, but a dog in the air. One of our guys has one. I had run into the wind to get the thing in the air for him. It's surprisingly heavy. Even once airborne it has little thrust, a.k.a. speed. I would not try this with an autopilot.
Thanks,
Paul
Comment by Tilman Baumann on August 29, 2012 at 9:15am That thing flies needs a lot of throttle and flies fast. It's no glider.
And how are EDF for vibration?
I'm sceptical. But why not? Prove us wrong. :)
Comment by Ellison Chan on August 29, 2012 at 9:24am So when HK says on the product page, are they being misleading?
One of the first things to strike you when flying the V-70 is how beautifully balanced it is, the pilot feels immediately at home and locked in, even at high speed. The aerobatic ability of the Zephyr is mind warping, combine this with the impressive off throttle glide and you have an amazingly wide flight envelope but open that throttle and you are greeted with a turbine like sound like no other EDF Jet, it's so addictive! Jaw dropping Looks, high speed performance, amazing aerobatic ability, quality, durability, practicality and innovation.....the Durafly Zephyr V-70.....the ultimate foamy!
Comment by Tilman Baumann on August 29, 2012 at 9:25am I'm not a Ardupilot expert. But if the software does not know how to handle V-Tails. Just plug in a V-Tail Mixer.
They can be bought for installation on the tail servo cables. Don't see a reason why this should not work.
Comment by Kabir on August 29, 2012 at 9:26am Thanks for the input guys, Presently I am torn between these. Please suggest.
Comment by Tilman Baumann on August 29, 2012 at 9:30am Are stable non linear flying planes (a lot of dihedral) actually the best choice for FBW?
They are for RC beginners. But autopilots are no beginners and might have more predictable responses with sporty planes.
The paparazzi project guys seem to concentrate on unstable airframes. I don't know if that is because they like the challenge or if they actually fly better.
Sorry to come up with such a random thought. But I guess that is what it all depends on?
Comment by David M Eno on August 29, 2012 at 11:37am Bixler/Skysurfer/Easystar or Skywalker are the first two planes you should think about owning. Both are good. You should have nothing to do with a fiber body until you have a lot of experience.
Comment by Ger Harris on August 29, 2012 at 11:59am I know you are trying to decide between those three airframes, but I also have to suggest a Bixler-1 as a glider. I can go 10 minutes from my house to a field with an excellent updraft and keep mine in the air for 40 minutes easy with 10% throttle and a 2100mAh battery. My neck gives out before the plane does.
There is a HUGE community and parts for the Bixler-1 for APM, FPV, and general RC. That doesn't even begin to scratch the surface of the sister planes - Sky Surfer and EasyStar. Must of the APM development here has been done based on the Bixler-1 airframe.
The Bixler-2 has been announced less than a month and I personally don't know anyone with it yet. In a way I hope you get it because I want to hear from someone else what challenges there were. If you want to pioneer on these airframes I encourage you to go for it - I appreciate this community, but just realize if you start on an airframe that few people have you may have problems getting specific answers to problems.
Good luck on your decision and we hope to see your progress soon!
Comment by Andy Grose on August 29, 2012 at 12:23pm I don't have experience with this airframe, but the comment above about a v-tail mixer...I can comment on that.
I purchased a FMA MX-80 V-tail mixer and a Great Planes V-tail mixer to use with my APM2 on a "Predator" ARF model. I was unable to get full control of the tail surfaces...only got up and right, no down and left. I gave up on rudder control and put both tail servos on a y-cable to the elevator channel and added a big rudder to the sub-fin on the plane. Much simpler that way! :-)
Andy
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
24 members
48 members
51 members
111 members
Powered by
