[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Very cool. Does this allow tuning of parameters (ie: PIDS's) via MP? Does the telemetry work? Will it work on an APM2, or with an APM1 oilpan installed if we want? Compass?
Hello,
The APMrover v1.0 firmware is fully compatible with the APM mission planner and you must set the PIDs as an ArduPlane. This is a light size version of the ArduPlane firmware with some changes so as to be compatible for a ground vehicle. It works of course with the APM v1 and APM v2 and with also the OilPan installed. No compass here is needed,
Regards, Jean-Louis
Below the APMrover PIDs tested in the video:
In the yellow rectangle, there a some news parameters for the APMrover:
ROV_AWPR_NAV: if set to 1 its allow the automatic Wp radius calculation relative to the ground speed.
ROV_GAIN: need to be set to about 5 so as to increase the gain of the wheels servo.
ROV_CL_NAV: if set to 1, allows a closed loop navigation,
Regards, Jean-Louis
Comment by Rana on April 25, 2012 at 1:03pm Nice attempt JLN ! For a autonomous Rover, Magnetometer is MUST.
Comment by Randy Ram on April 25, 2012 at 3:23pm Congrats. This is good.
Can we get this added to APM Trunk as a new folder for Rovers?
Looks like ArduRover already exists, can we just blast it, or make ArduRover2 folder in trunk? At least until a decision can be made to get rid of the old ArduRover code.
Comment by Anis Nielsen on April 25, 2012 at 4:45pm Mighty cool Jean Luc, excellentissimo, Bravo! ;
I've been following your thousands of experiments and videos for at least 10years, you are phenomenal, really, and thank you very much again for sharing .. again :)
Is there any description of the radio setup somewhere? I've got a crawler just dying to try this out...
720 members
203 members
1355 members
207 members
Powered by
