Found some good bugs already. An issue with auto trimming being activated due to unusual Radio configurations fixed. Mavlink support is now up to par with APM. and A compass bug in the library squashed.
I revved the firmware's EERPOM fingerprint. You must redo the setup completely. (except ESC calibration.)
Thanks for the feedback!
Jason
I can tell you right now the camera stabilization works well. I had to make a couple of small tweaks to the math, and it's probably not the right way to do it, but I'll send it to you.
Comment by Taylor Cox on May 9, 2011 at 8:08pm
Comment by Nigel on May 10, 2011 at 10:56am I know Jason is aware of Mavlink issues but for the record, with today's current code I get different data from the USB port than from the UART. The USB data seems to be complete with full telemetry and GPS whilst the data from the UART only seems to contain servo data...
(This is just for info - I know this is still being worked on)
Comment by emile on May 10, 2011 at 12:30pm
Comment by Magellan on May 10, 2011 at 12:34pm
Comment by emile on May 10, 2011 at 12:49pm @Magellan, thanks for the answer. I was used to the always there "408" value. So I bet this is a 1G pulling down just a matter of showing it in a different way (maybe makes more sense now :))
Ok, so here is another Q.
In the PIDs D is a real D or is it the P-Rate as for the former AC?
Cheers,
Emile
Our standard PID loop doesn't take into account the Sensor data for D term.
This was Jose's original approach. Technically, it's a standard PID loop. Rate can be derived from a saved angle, or directly from the sensors. The reality is that we could use the saved rate and make it 100% standard. But it's not worth changing because we also use some nice constrains in there too.
Comment by Peter Seddon on May 10, 2011 at 1:14pm
Comment by Vincent Mees on May 10, 2011 at 1:22pm
58 members
1355 members
207 members
52 members
Powered by
