Comment by Daniel Gru on July 4, 2011 at 3:42am Great, very motivating...
I am testing my APM-Hardware on a selfbuilt quad, then i amswitching to my Y6, hopefully end of the week.
Which firmware version were you running?
Which flightmodes have you tested? Only stabilze or loiter as well?
Regards
Daniel
Comment by Kevin Vertucio on July 4, 2011 at 4:00am
Comment by Daniel Gru on July 4, 2011 at 4:09am You know you have to have your throttle stick at hover point when switching to Loiter, because it uses the momentary stick position as the defined throttle for holding hight..
Can it be that you had your throttle stick very low, when you switched into loiter?
Regards
Daniel
Comment by Kevin Vertucio on July 4, 2011 at 4:35am Hmm. It's possible, but I don't think I was below hover. I was at about mid-stick. Here's a clip of it going from alt_hold to loiter.
Comment by Kevin Vertucio on July 4, 2011 at 5:07am
Comment by Kevin Vertucio on July 4, 2011 at 5:50am Max,
I am guess I should stay away from those black props. I used to use them on my quad because they were cheap and didn't chip when I crashed. I had these APCs laying around as spares from the quad projet so I just installed them on this frame.
Here are some photos of the frame. http://flic.kr/s/aHsjvnNWwm
Here's some photos of the frame. http://flic.kr/s/aHsjvnNWwm
Comment by Kevin Vertucio on July 4, 2011 at 6:07am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.691 members
87 members
51 members
7 members
131 members
Powered by
