  • T3
    Is there any plan to convert over some of the incompatible files in the Ardu* libraries? FastSerial had an issue with one line of a virtual function and then I believe the 406 library also had an issue with WProgram.h needing to be changed over to Arduino.h.
  • I have attempted to compile some of the previous versions with the 1.0 and many will requires lots of recoding. However with this said, I believe this version is a step in the right direction.
  • yep, i believe that the arduino shop will shortly have some initial dev test boards. they have been in dev with arduino for a while. i think there has been a delay getting the cpus in quantity but it could simply have been time to pass beta stages.
  • Does this mean the new arduinos are not far down the road?
