I was finally able to test 2.5 over the weekend and added a few tweaks to the code.
Here's what I hope is the final release.
As the new Manual gets formatted, you can view it at: http://code.google.com/p/ardupilot/wiki/ArduPilot25
Until the content is finally moved over the 2.4 manual is still a great resource.
Ardupilot_25_RC2.zip
Bonus - If you look check out the Waypoint_writer_25.pde file in the test suite, you can upload relative waypoints. This isn't supported in the config tool yet.
Jason
UPDATE -
A lot of people were having trouble with the GPS code and LEDs. I reworked the GPS parsers today to iron out some things. They were nothing that would interfere with flight, but I highly recommend using this new version. I've also added the ability to scale down your plane's roll based on airspeed. This should help planes that turn faster when they go slower. We may tweak this a bit in the future, so I'm looking for feedback on it. Note you can always turn it off in your header file with this line:
//6-4
#define AIRSPEED_TURN_P 1
see the header file for more instructions
Comment by Ryan Beall on January 31, 2010 at 11:18pm
Congrats Jason, How did the flights go?
Comment by Rana on February 1, 2010 at 1:44am
Congrats Jason !
Pl. share more about your flight experience. Post video if any.
Comment by Rana on February 1, 2010 at 2:04am
Hi Jas !
Why the released source zip "Ardupilot_2.5.0rc.zip" is not available in the download area at google code ?
http://code.google.com/p/ardupilot/downloads/list
Admin
Comment by Thomas J Coyle III on February 1, 2010 at 5:35am
NS,
It appears to be now as I just did a download from the google code area.
TCIII
Comment by Chris Anderson on February 1, 2010 at 9:20am
Thomas, I think he meant the zip file. I've now put the zip file in the Download area here, although I won't feature it until we've got enough feedback from the community that it's as stable as we think.
Comment by Rana on February 1, 2010 at 9:57am
Chris, now its there, thanks !
Comment by jasonshort on February 1, 2010 at 10:27am
Hi Guys,
The flights were very informative. I cleaned up some startup code to make the status LEDs match the prior versions.
I had a lot of trouble with the IR under reporting it's angle. We had quite the cold and foggy day and the sensors had some issues. I lowered the IR_max minimum value and the problem went mostly away. I would love to do a better calibration in the field - say hold the plane at 45° and set that as 45°. The new value is in the code now so there is nothing to do.
I also had issue with over steering at slow speeds. I took a tip from Ryan and added a proportional scale for roll_P so that it goes down the slower you go. I limit that to about a 60% reduction. I start reducing below 30 from the pressure sensor. That may need to be adjusted on a per plane basis but for now, it's low and pretty safe.
I also lowered roll_I because the easy star doesn't seem to need it much if at all.
Tim flew the FLY_BY_WIRE mode which lets a novice pilot control the plane with ease. The FBW mode was also instrumental for debugging my sensor issue.
Loiter looked good. I reduced the radius in the default header as Chris's plane looked to be flying well outside the radius. I think this has to do with the plane not aggressively holding the line enough. I really need to hook up telemetry and refine this, but it does work nicely! Maybe Ryan you can help here.
Jason
Comment by Reto on February 1, 2010 at 11:43am
Cool, ver. 2.5 goes in field testing. I have a question: at this point, only uBlox and EM406 in binary mode are supported as per the current versio of 2.5 manual. Is the implementation of Locosys GPS and NMEA parsing planned or abandoned? Thanks for your feedback.
Comment by Chris Anderson on February 1, 2010 at 11:47am
Reto, NMEA is in the code. It's supported:
Comment by jasonshort on February 1, 2010 at 11:54am
NMEA is implemented but not fully tested. Anyone want to help? PM me.
Comment
