[This home page has moved. It's now here]
Comments are closed for this blog post
Comment by Jhon on September 24, 2008 at 4:28pm
how alt-hold work?
the altitud is specified in the firmware or ArduPilot will try to hold in the altitud plane is, when fail safe turns on ?
Comment by Chris Anderson on September 24, 2008 at 4:32pm
Out of the box, altitude hold maintains the altitude the aircraft is at when the autopilot is turned on. But you can modify the code to include different altitudes with each waypoint. The code is open source, so ArduPilot can have any functionality you want to add. It's also set up to take external pressure sensors if GPS altitude is not enough for you.
Comment by Jhon on September 26, 2008 at 7:22pm
what you think about add a second gps connector in the board in order to connect also an osd using same gps?
finaly will be possible to buy just the cpd4 head and connect it to ArduPilot? or its necessary the use the cpd4 block ?
will it be compatible with that micro gps ? http://www.nghobbies.com/cart/index.php?main_page=product_info&products_id=162
im very happy to see that project progressing,
Comment by Chris Anderson on September 26, 2008 at 10:25pm
We have no plans to connect a second GPS connector for an OSD, but you're welcome to modify the board to do that yourself if you'd like
For ArduPilot, you need the CPD4 head and block; for ArduPilot Pro, which is not available yet, you'll just need the head.
We are planning to make ArduPilot compatible with 5HZ GPS modules, including micro gps and Ublox5. Stay tuned.
Comment by hoopty on October 5, 2008 at 8:32am
I know rear read read. I figured it out from the sch.
Comment by hoopty on October 9, 2008 at 3:45pm
any idea when the big day will be?
Comment by Chris Anderson on October 9, 2008 at 4:47pm
We're working as fast as we can, but I still don't have a date for you. Making a few boards is easy. Making hundreds, reliably, is hard.
Comment by Jhon on October 17, 2008 at 8:41am
does it work with V-Tail planes like EPP Eagle ?
Comment by gman on October 19, 2008 at 9:55pm
Hi everyone, I am a aerospace engineering college student who stumbled upon this website and I am very excited.
Is there a way that I could use something like a XBee and make real time changes to the GPS way points? I'm not sure if there is a ground station in the works, but I think it is something that is definitely worth it.
Comment by Alberto on October 20, 2008 at 1:00am
Hi : I wonder how will the ardupilot react in case you loose rc signal or just have weak signal ( control in and out ) and you haven´t engage the autonomous mode ...??
