I'm currently copter-less and waiting on new motors to arrive from China, so I had some spare time this weekend to do a quick side project. It's a ground up re-write of the original Ardupilot using the latest Libraries for APM. The only difference is I had to use some tweaks to avoid filling up all the flash ram. With the Ardupilot GCS code, it's less than 1k from full. But it's all in there.
I could use some help testing because I can't get away to fly anymore. All of the systems seem to work correctly. The only trick is that the AP_config.h file needs your exact radio pwm values.
You can use the AP_RC_Channel example sketch in the Library to get those values.
Otherwise it works with HappyKillmore's GCS and the latest GPS modules.
RAM is totally freed up using the PSTR macro so no more code crashes...
For know you can leave a comment here for bugs and fixes. Then I'll do a Beta and start using the issues list.
Code is on the Ardupilot Trunk and called Ardupilot_2_8
http://code.google.com/p/ardupilot/source/checkout
Use the latest Libraries from Ardupilot Mega.
If none of this post makes any sense, I wouldn't bother downloading. Just wait for a Beta.
Jason
Comment by DaveyWaveyBunsenBurner on May 2, 2011 at 11:11pm
Comment by Christof Schmid on May 3, 2011 at 1:13am To bad I changed to APM 2 weeks ago. But I will get that right first.
Best
Christof
Comment by Dario Lindo Andres on May 3, 2011 at 6:49am Hi Jason!!
Thanks for your awesome job! I can test your changes with my IRE (http://diydrones.com/profiles/blogs/ardupilot-range-video-osd), but for now weather is too windy here in Spain.
Regards!
Dario.
Comment by healthyfatboy on May 3, 2011 at 7:29am I assume you have to use the IMU with this or can you still use it with the thermopiles? I was going to try and test it out until I saw that the elevons aren't working yet and I've got it on a delta wing right now. I suppose I should get all the AP functions working on v2.7 first before I move on but once I get there, I would be willing to test some.
I thought I was completely old tech with my APL and thermopiles but maybe I'll get another update!
Thanks Jason.
Comment by Jim on May 3, 2011 at 8:23am Thanks Jason. I've been hoping that there was life in the old APL. Your efforts are very appreciated.
Jim
The elevons *may* work. You can definitely try. This works with thermopiles or the IMU. I've not tested the IMU yet.
Jason
Comment by Andrew Brygin on May 11, 2011 at 4:53am In order to get ArduPilot_2_8 compiled with GPS_PROTOCOL_IMU, I needed to make following changes:
* add gps driver initialization to lines 54 -57:
#elif GPS_PROTOCOL == GPS_PROTOCOL_IMU
AP_GPS_IMU g_gps_driver(&Serial);
* replace obsolete decode_gps on line 300 with following code:
update_GPS();
roll_sensor = ((AP_GPS_IMU*)g_gps)->roll_sensor;
pitch_sensor = ((AP_GPS_IMU*)g_gps)->pitch_sensor;
Is AP_GPS_IMU a right class to operate with ArduIMU here?
Thanks,
Andrew
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.5 members
1282 members
183 members
674 members
116 members
Powered by
