[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
- ArduPilot board
- Shield expansion kit with airspeed sensor
- GPS module (uBlox5 recommended)
- XY and Z sensors or ArduIMU+
- FTDI cable for programming
- [Optional] Two Xbee modules for wireless telemetry. This one in the air and this one with this antenna on the ground/laptop side. You'll also need two Xbee adapter boards. You can connect the airborne Xbee adapter to Ardupilot Mega with jumper wires.
Open source extras:
Recommended UAV setup:
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
Cool optional extras for your UAV:
Comment by SciFly on October 24, 2010 at 12:09pm
Comment by Richard Hirst on November 27, 2010 at 9:50pm
Comment by Richard Hirst on November 27, 2010 at 10:48pm
Comment by Eugene on December 7, 2010 at 9:23am Hi,
I will be searing a Locosys LS20033 GPS between Ardupilot and EZosd. I would appreciate if anyone could tell me if i need to power the GPS from the Shield in order to make use of the GPS auto shut-off feature when uploading or it is OK if i just provide the Shield only with the GRD and Rx wires coming from the GPS.
Comment by Samuel on December 15, 2010 at 3:07am Hi,
some people from fpv-community.de and me want to create a german version of the manual and setup process as well as change the code comments to german for those ppl that doent speak english very well. Since we have some computer science pros in our team we might find some optimations etc, of couse we will post them in the english section as well if we find some.
Just wanted to ask if its ok for you guys to create a google code project where we support the german people that want to run an ardupilot.
Cheers Sam
Comment by Samuel on December 22, 2010 at 3:48am Ok we started on a german manual. Its located here: http://fpv-community.de/comm/wiki/index.php?title=Ardupilot
Its still work in progress, but we will add things everyday.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.48 members
51 members
1299 members
24 members
111 members
Powered by
