Hello,
Many people are using Ardupilot on easystar airplane.
What other airplanes are being used with Ardupilot and how to adjust Ardupilot code for the athoer airplanes?
Roberto
Comment by Chris Anderson on August 30, 2009 at 11:03am
Roberto, please do not post your questions as blogs. They should be in the discussion forum instead.
Also, if you will spend a little time reading the material already on this site, you will find your answers. But the short form is that you don't "adjust the code" for other aircraft; you adjust the settings in the configuration file (default is easystar.h)
Comment
