So I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
Comment by Rick M on June 24, 2012 at 3:37pm @Earl, what radio transmitters/amplifiers are you using? In particular, how are you getting 1W 3DR? Thanks!
Comment by james sowell on June 24, 2012 at 3:40pm 2:18
Comment by Toby Mills on June 24, 2012 at 7:33pm Yes, I flew a flight out to 8km this morning, no problem at all, was just starting to drop off 99% at that distance, but goes down hill quickly at 10km.
I am using one of these...
http://www.gowifi.co.nz/coming-soon-new-products/900mhz-13dbi-arc-e...
Relatively expensive, but very large patch antenna that works really well.
Not sure on my takeoff weight, but using a 14 x 8 prop.
The flight this morning was 18km round trip, cruising at 50kph and used only 2200mAh of the 7400 onboard.
Also @Rick, I tried your PID settings and they work better than mine. My flight was in reasonably high wind this morning and it tracked well. I think your PIDs should form the basis of a parameter file for the X8.
Nice plane.
Comment by Toby Mills on June 30, 2012 at 9:39pm Did anyone improve on the posted PID's.
These work ok for me in no wind, but in higher wind I get pitch problems and nav issues.
Can someone please advise the recommended control throws for the X8
Comment by Alexandre Moreno Richwin Ferreir on July 9, 2012 at 11:52am I`m playing with the PIDs of X8 too. Saturday we had a flight with really strong wind and APM managed to navigate the X8 through a 35km flight path. But I`ve noticed a lot of variation in Roll when flying against wind (snaking). In other hand when flying in favor of the wind the roll was ok but the Pitch had a lot of variation.
Anyone had similar results or have a hint about it?
Comment by Toby Mills on July 9, 2012 at 5:55pm Hi Alexandre,
Yes I get exactly the same results as you. lots of roll into the wind and pitch problems with the wind.
Comment by Gustav Kuhn on July 10, 2012 at 2:43am Hi guys, are you using an airspeed sensor, or relying on GPS speed?
Because if you only use GPS speed, your true airspeed is going vary tremendously.
I saw similar results on my Discovery, I forgot to connect the Pitot tube once, :-(
Comment by Rick M on July 10, 2012 at 2:54am We were definitely using airspeed.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.106 members
1298 members
51 members
87 members
47 members
Powered by
