From the Google Earth blog:
When discussing the new Ovi Maps 3D a few days ago, one interesting point about their maps are how they are generated -- hundreds of aerial photographs, automatically converted to 3D.
It's apparently growing into a popular technique, as Pix4D is showing off some similar technologies.
In the article they mention using the Swinglet CAM as a great way to capture the imagery for uses like this. The "4D" part of the equation is time; you can view the progress of 3D buildings through time, assuming you've done enough captures of a particular area.
@Ritchie The problem is that ppl with sufficient background are already employed at the university.
http://www.micmac.ign.fr/
http://www.micmac.ign.fr/index.php?id=3
@Krzystof
I am unable to find even a single open source system. Notoriety does not mean fact and I'm sure between a group of people with sufficient background could decypher anything within the code, big or small.
@YureZzZ
You cannot fly within 3 miles in the UK and similar distances around the globe. Taking pictures behind a fence on the ground is not using a UAV :)
@Ritchie "I'm waiting for an open source version so we can get into the maths."
I am pretty sure you several open source soft for this in Europe (once per developed country).
The software is usually several MB of source code and even when you got it it is useless until you spend 1 year learning it. Such projects are notoriously beyond uynderstanding for a non-professional (not a researcher in the field).
They come as jpeg because 750 RAWs are likely to explode everything, while this is only one hour of flying.
Also continuous shooting rate of practically all cameras shooting RAW is slow, some 10s. (don't look at the specs, they never publish continuous shooting rate, crowd says it depends on SD card but it doesn't, it most often depends on internal processing speed since the cards are very fast now, varies widely from make to make and is never published since nobody really cares).
This is a service...
http://www.pix4d.com/aboutus.html
Also... there is standalone
http://www.pix4d.com/uavProductsLight.html
@brakar
Use Erdas ER Viewer for huge files. For mass-viewing hundreds of smaller images the best is AcdSee.
