Autonomous flight mission with the ArduPlaneNG v2.x R5 and AIOP IMU board on Maxi Swift flying wing
Here a video of an autonomous flight with a Maxi Swift flying wing fully piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board.This is a porting of the ArduPlane v2 (v2.4+v2.5) firmware and special addons and improvements for the AIOP board that I have added.
The wind was 15 km/h gusting 22 km/h. The flight was very stable in spite of the gusty wind conditions.
Setup:
  • IMU board: All In One Pro (AIOP) v1.0 from CRIUS,
  • GPS: Crius CN-06 (Ublox NEO-6)
  • AirSpeed sensor: MPXV5004DP (from a old ardupilot one shield)
  • firmware ArduPlaneNG V2.x R5, porting of the ArduPlane v2 + special addons for the AIOP v1 IMU board by JLN
Flying Wing: Maxi Swift from MS Composite (1m40 wingspan)
  • brushless motor Spitz 30 850 kV, 360W with a propeller GWS 10x4.5
  • Lipo: 3S EVO25 2650 mAh
  • Receiver: Turnigy 9X8C v2
  • Transmitter: Turnigy 9x with Er9x firmware
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Tags: DRONE, UAS, UAV, ardupilot, autopilot, glider
Comment by Rui Manuel Cravo Marques on August 16, 2012 at 6:05pm
Rana, 110$US or 110 British pounds ?
Comment by Harry on August 16, 2012 at 10:06pm
 Jean-Louis, vous faites un travail brilliant.  Beaucoup awesome.
Comment by YureZzZ on August 17, 2012 at 2:43am
@Rana - is this NEO-6M really working as stated? I don't see its antenna on the board.
Comment by Jean-Louis Naudin on August 17, 2012 at 2:47am
Hello YureZzZ,
The Ublox CN-O6 GPS antenna is the ceramic squared piece on the top... see below:
Comment by YureZzZ on August 17, 2012 at 2:57am
Thanks Jean-Louis!
I think I found the cheapest way to get it:
Crius CN-06 GPS Receiver Module $26.51
CRIUS ALL IN ONE PRO v1.0 Multi-Copter Flight Control Board Support...
It is cheaper than Rana suggested, except that this AIOP board doesn't say "Support MegaPirateNG and MultiWii". Pictures are the same. So is it safe to buy?
Comment by Rana on August 17, 2012 at 8:50am
YureZzZ, I have not tested NEO-6M GPS but It should work as it is tested by JLN.
I was following up the development at MegaPirate Next Generation, so purchased CRIUS ALL IN ONE PRO v1.0 board quite early. Since microcontroller is same (ATMEGA2560), people at MegaPirateNG are continuously porting the latest code developed by the Arducopter Team, to that board.
Comment by Austin H on August 17, 2012 at 10:20am
amazing work Jean !
would it be possible for you to post the modifications you did to the board
 glad to see other boards being discussed here
Comment by Jean-Louis Naudin on August 17, 2012 at 10:35am
Hello Austin,
Here the connection diagram that I have used for the AIOP in my Maxi Swift flying wing with the ArduPlaneNG 2.x R5:
Comment by Jean-Louis Naudin on August 17, 2012 at 10:43am
Below the connection used with my Easyglider with the AIOP and the ArduPlane v2.x (R4 or R5):
Here my Turnigy Er9x setup for the Easyglider:
Comment by Rana on August 17, 2012 at 9:44pm
Excellent JLN !
Comment
