You always have that ONE flight where nothing goes right. 7-27-12
The balloon slipped off the filling neck and got away. We had a backup balloon ! The second helium tank was EMPTY.
Dang..what luck.
Soooo... I will show pictures of the X8 wing we will try to launch Friday 8-3-12.
The Big Wheel antenna on the front is for the 5 WATT ATV TX on 434 mhz. (Yes I am a ham N8TV)
Antenna on wing is the 10 watt APRS antenna on 144 mhz.
Notice the annoyance deterrent ?
5 watt ATV Tx, APRS (under card) and battery.
Nichrome cut down system activated by time or a command from the Mission Planner and APM 2.5
It is released by a command from the Mission Planner at a LOW altitude. (joke)
I hope the Friday 8-3-12 launch goes well.
Earl
Comment by Michael Krader on July 30, 2012 at 11:07am looking good, hope things go good.
Comment by arashi on July 30, 2012 at 12:08pm Nice!
What is the expected drop altitude?
Are you using an RC control link also?
Comment by Earl on July 30, 2012 at 12:13pm Drop for first flight <5000 Ft to test everything. Yes RC as well as Mission planner. Hope to use MP only. Delay may be a problem. But the APM will fly it and do RTL and Landing. All the hard stuff I am not good at.
We will have a FPV camera in the nose with the 5 watt video transmitter.
Earl
Have you super reinforced that X8 I hear tell that they like to flap like a bird. I guess your one is reasonably light though without power system and motor, 10watts on 2m are you trying to hot wire cut the wing ;-) For sure people will hear it miles and miles away. Best of for the next try.
Comment by Earl on July 30, 2012 at 12:29pm
Comment by Earl on July 30, 2012 at 12:33pm
Comment by Kevin Brown on July 30, 2012 at 1:07pm why dont you try something Like spiderwire for your cordage very fine and very strong melts in ms with your nicrome cutter. much less load to release I used something similar to release some underwater sensors
Comment by Mike on July 30, 2012 at 1:26pm Just posted this over on AeroBalloon forum, forgive double posting but may be helpful here . . . On high altitude balloon projects to avoid Arduino flight computer failures due to outside systems, for example, cutdown, communications, or sensor controllers from getting stuck in a subroutine, watchdog timer within Task Scheduler for Arduino will reset the flight computer. Source: Hack a Day
Comment by Kevin Brown on July 30, 2012 at 2:40pm Great work by they way.....
I live in the Key and have wanted to drop something like this into a hurricane for years as they go by my house...
the nice thing about the braided fishing line (spiderwire) you can get it as low as 5 to 10 lbs for tournament certified line...
Comment by Kevin Brown on July 30, 2012 at 3:35pm No problem, I understand the max load limit
from the looks in the photo it looks like a very beefy cutter, with a very large dia. wire and very long = massive load
and long heat time. sized right a button cell could drop a 300 lbs load no problem because of the dia. of the spiderwire is so thin hair size
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.106 members
1279 members
671 members
183 members
182 members
Powered by
