You always have that ONE flight where nothing goes right. 7-27-12
The balloon slipped off the filling neck and got away. We had a backup balloon ! The second helium tank was EMPTY.
Dang..what luck.
Soooo... I will show pictures of the X8 wing we will try to launch Friday 8-3-12.
The Big Wheel antenna on the front is for the 5 WATT ATV TX on 434 mhz. (Yes I am a ham N8TV)
Antenna on wing is the 10 watt APRS antenna on 144 mhz.
Notice the annoyance deterrent ?
5 watt ATV Tx, APRS (under card) and battery.
Nichrome cut down system activated by time or a command from the Mission Planner and APM 2.5
It is released by a command from the Mission Planner at a LOW altitude. (joke)
I hope the Friday 8-3-12 launch goes well.
Earl
Comment by Michael Krader on July 30, 2012 at 11:07am
looking good, hope things go good.
Comment by arashi on July 30, 2012 at 12:08pm
Nice!
What is the expected drop altitude?
Are you using an RC control link also?
Comment by Earl on July 30, 2012 at 12:13pm
Drop for first flight <5000 Ft to test everything. Yes RC as well as Mission planner. Hope to use MP only. Delay may be a problem. But the APM will fly it and do RTL and Landing. All the hard stuff I am not good at.
We will have a FPV camera in the nose with the 5 watt video transmitter.
Earl
Comment by Gary Mortimer on July 30, 2012 at 12:16pm
Have you super reinforced that X8 I hear tell that they like to flap like a bird. I guess your one is reasonably light though without power system and motor, 10watts on 2m are you trying to hot wire cut the wing ;-) For sure people will hear it miles and miles away. Best of for the next try.
Comment by Earl on July 30, 2012 at 12:29pm
A little clarification on how wire rope cutter.
Earl
Comment by Earl on July 30, 2012 at 12:33pm
Comment by Kevin Brown on July 30, 2012 at 1:07pm
why dont you try something Like spiderwire for your cordage very fine and very strong melts in ms with your nicrome cutter. much less load to release I used something similar to release some underwater sensors
Comment by Mike on July 30, 2012 at 1:26pm
Just posted this over on AeroBalloon forum, forgive double posting but may be helpful here . . . On high altitude balloon projects to avoid Arduino flight computer failures due to outside systems, for example, cutdown, communications, or sensor controllers from getting stuck in a subroutine, watchdog timer within Task Scheduler for Arduino will reset the flight computer. Source: Hack a Day
Comment by Kevin Brown on July 30, 2012 at 2:40pm
Great work by they way.....
I live in the Key and have wanted to drop something like this into a hurricane for years as they go by my house...
the nice thing about the braided fishing line (spiderwire) you can get it as low as 5 to 10 lbs for tournament certified line...
Comment by Kevin Brown on July 30, 2012 at 3:35pm
No problem, I understand the max load limit
from the looks in the photo it looks like a very beefy cutter, with a very large dia. wire and very long = massive load
and long heat time. sized right a button cell could drop a 300 lbs load no problem because of the dia. of the spiderwire is so thin hair size
Comment
