This is a mechanism in place to launch the X8, when its weight is 5.3 kg. his recovery is done by parachute. http://diydrones.com/profiles/blog/list?user=15tihx7n8mzza
the mechanism is very reliable for heavy winged lanzameinto. unfortunately my x8 fell into a bad spin maneuver and crashed, and I could not keep doing pruenbas with APM.
Comment by Nat W on January 6, 2013 at 12:23pm Very interesting, i just couldn't help but think what would of happened if the bungee made it crash into the ground.
Comment by Carl La France on January 6, 2013 at 7:11pm Very Nice ! I like the tie back on the tripod. Having the tripod probably shortens the bungeee 50 to 75 feet.
@Nat W with a bungee the learning curve is usually trial and error and quick . the wings must be level or it will go
veering off to one side maby cart wheel . Nose down bite the dust , and it should be set up for a clean release if it doesn.t release it will be a spectacular launch to altitude only to come up tight on the bungee and come right back down. with a bit of practice a bungee offers a efficient economical launch to altitude over rough terain
Comment by viky on January 7, 2013 at 2:09am
Comment by jim C. on January 7, 2013 at 5:36am Viky, 10,000 mah, can fly about 1 hour and 15 minutes.
Comment by viky on January 7, 2013 at 6:03am
Comment by jim C. on January 7, 2013 at 6:44am viky, x2 4cell lipo 5000 mah , and motor 780 kv, prop APC 12x6.
bungee http://www.hobbyking.com/hobbyking/store/__10609__HobbyKing_8mm_Sil...
Comment by viky on January 8, 2013 at 1:35am
Comment by viky on January 8, 2013 at 1:45am
Comment by jim C. on January 8, 2013 at 6:19am the triangle-shaped bars are fixed, the point of support for the bungge, the box is rectangular.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1298 members
87 members
693 members
7 members
48 members
Powered by
