Complete acrylic ArduCopter set on Ponoco, with spare parts
Complete set of acrylic parts needed to build ArduCopter frame. You can find the files here:
http://www.ponoko.com/design-your-own/products/arducopter-set-5696
All files are under Attribution ShareAlike license (free).
Set uses two Ponoco P1 sheet sizes (181.0 mm long x 181.0 mm wide).
Suggested material: Acrylic - Clear 3.0 mm
Sheet 1:
Material: $2.00
Making: $13.57
Total: $15.57
Sheet 2:
Material: $2.00
Making: $13.80
Total: $15.80
Set has spare parts for all components, in case of flight crashes with frame damage. Content:
- Dome arch (4 + 2 spare)
- Dome center lower (1 + 1 spare)
- Dome center upper (1 + 1 spare)
- Motor mount lower (4 + 2 spare)
- Motor mount upper (4 + 2 spare)
- Landing gear fin (4 + 2 spare)
Total: 28 parts
Based on the opensource design:
http://code.google.com/p/arducopter/source/browse/#svn%2Fbranches%2...
Correct line widths as suggested in Ponoco design templates, which is not true for previous Ponoco ArduCopter files. Enjoy.
Tags: ArduCopte, acrylic, frame
Admin
Comment by John C. on April 28, 2011 at 11:04am
AWESOME. Nice work. Already did this service with the upper rings, and it came out well.
Admin
Comment by John C. on April 28, 2011 at 11:33am
Just ordered mine...nice and easy.
Comment by Joe Bloeski on April 28, 2011 at 11:45am
Its ponoKo not ponoco.
Distributor
Comment by Dany Thivierge on April 28, 2011 at 12:12pm
Nice, not bad, $45 shipped to me in Canada... will keep that in mind if I need it.  would have been nice to order it all in black except the motor mounts for illumination... :)
Comment by Chris Anderson on April 28, 2011 at 1:10pm
Ivan, which files did I get the line widths wrong on? Ponoko accepted all of them, which usually means that they're right (0.01mm)
Comment by Ivan on April 28, 2011 at 1:20pm
When I downloaded them they said 0.01pt, not 0,01mm. I think you may had your document defaults wrong. Now they are 0.01mm for sure, something like 0.028pt.
Comment by Chris Anderson on April 28, 2011 at 3:12pm
Points are smaller than mm, so that's fine. The line just has to be 0.01mm or smaller, which my files were. Ponoko just wants to the lines to be small enough for the laser to make one pass, not try to carve out a channel with multiple passes.
Comment by Joe Bloeski on April 28, 2011 at 6:26pm
Surely the laser has a fine cutting width but is it really 0.01mm???  This seems too small, I priced out a few designs but haven't followed through with one yet.  I did my designs in Inkscape (the only free supported program) and found that having to get the lines to 0,0,255 (Blue) and 0.01mm made the lines difficult to see on the screen when zoomed out to see the whole panel even on the smaller P1 panel size.  if they allowed a larger line width it would be easier to check drawings and see details without having to zoom in to make the lines thick enough to see.  I assume that no matter what the line thickness is they would cut don the center any way and the process seems to burn/char the edges of many materials anyway so I can't believe the 0.01mm spec.
Comment by John Leichty on April 28, 2011 at 8:48pm
Ponoko quantifies their laser cutter kerf on different materials and thicknesses, below (0.20mm for 3mm acrylic).
http://blog.ponoko.com/2008/09/11/how-much-material-does-the-laser-...
Comment by Joe Bloeski on April 28, 2011 at 11:41pm
As  a general average the kerf numbers seems to be right about 0.2mm (20 times greater than their required line width.  I think it would be much easier to work with that line width (weight) than the recommended size.  I'm impressed that they can cut such a fine line and that is relatively constant over depth and material variations.
Comment
