This is a port of Flytrons USB2PPM Project Compufly with enhancements
You can use multiple usb sources and map any axis and button to any channel of your choice.
You can also map multiple buttons to the same channel and adjust the ppm value to them for a 3 way switch with 3 buttons type set up
Everything is kind of setup for my CH Products set up with joystick throttle and rudder at the moment.
Check out the google code page and try it out for yourself. Make sure to read the wiki pages fore more info.
Google Code: Joystick to PPM
I am looking for Java programmers and testers to help work out bugs. If you think you fit the build email me and I'll add you to the list.
Screen Shots
aircool00 at g mail dot com
Cheers,
Ryan
Hi Ryan, great project! I see linux serial and parallel drivers in the lib folder. Have you tested it in linux?
After looking at USB2PPM on the website, I still a little confuddled about how the output side works, and there's talk about directx. Would you explain how the output side works, and how it hooks to a transmitter module?
Comment by Melih Karakelle on October 11, 2011 at 5:43am @Ryan,
Looking awesome!!
I just tested. It's working flawlessly with Windows7 32 bit :)
@Gord,
The compufly including usb to serial converter chip (CP2102) and OS finding it as a serial port. You dont need DirectX for using it, some simple serial commands enough. You got 2 option for controlling your plane. You can plug it on your transmitter's trainer port or connect directly to transmitter module's ppm input without using an RC transmitter body(direct ground station application).
Comment by Ryan C Smith on October 11, 2011 at 10:57am @Gord
I had my blinders on when setting everything up and failed to mention that you need to have a Compufly USB2PPM device from Flytron.com Melih created this device and the original opensource software. My new project is a port to Java from Delphi 7. There have been some new features added and hopefully after some feed back we can flush out some bugs and make a list of more features to be added. I am excited I got the seal of approval from Melih and hope to hear back from those who have downloaded the source and program.
That's okay Ryan, I assumed the need for a Compufly.
Thanks fellows. I'll have to do some searching on PPM, don't understand how a uart can output ppm.
Comment by Kirill on October 11, 2011 at 11:57am A little out of topic, but maybe someone could give me an advice. I'd like to make an inverse task - to make PPM2USB converter to send PPM signal from my transmitter into USB port of PC and emulate a joystick.
Do you mean like the adapters available for most flight simulators?
Comment by Kirill on October 11, 2011 at 12:08pm Yes, like those ones. But I'd like to make one by myself. I already know how to decode signal (I've chosen Arduino for this, AtMega328) and send it to serial. But I'm wondering, what's next...
Comment by Ryan C Smith on October 11, 2011 at 12:09pm @ Krill
I made a post on RC groups a little while back on how to do this here
Hope that helps
Cheers
Ryan
Comment by Kirill on October 11, 2011 at 12:20pm Yes, it's similar, but I would like to use a transmitter instead of PC joystick. Anyway, thanks for the link!
Comment by Ryan C Smith on October 11, 2011 at 12:25pm Well in that case you will want one of these
Deal Extreme
USB G3/G5/G5.5/FMS/AeroFly Flight Simulator Dongle
12-in-1 USB 2.0 Almighty Flight Simulator Dongle
HobbyKing
USB Simulator Cable XTR/AeroFly/FMS
Or my be cheaper on Ebay
Cheers
Ryan
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.16 members
182 members
86 members
51 members
671 members
Powered by
