Considerations for an Official Tri-Copter Frame?
I'm starting to see tri-copters becoming more and more popular, so I'm asking the DIYDrones community if there is any interest in making a tri-copter frame that has interchangeable parts with the quad-copter frame.
3689413469?profile=original
I've put together a rough draft of a 2D laser cut sketch of a possible main board and carrier board. I think the only thing that would require some change other than the two boards would be the dome ring. The rest of the parts should be the same, and we can even use the standard quadcopter power distribution board too. I'm not very good at 3D modeling, but I'm hoping this could be a community effort.
3689413528?profile=original3689413554?profile=original
And here are the 2D Illustrator files:
carrier_board.ai
main_board.ai
    We still working on it. Christmas and everything just stalled our Tri needs for now. We created even new sets for center plates with Max and he is now test running those.
  • I may need to rethink this... there's over 60$ of laser cutting in that layout.
  • A first try. I'm going to print it and try and get an idea how it all fits together before making a test order on Ponoko. Not too long though, 2.3 mm P2 size delrin is free right now!
    3692318418?profile=original
  • Sure go for it. I'm glad it's not going to waste :P.
  • This thread died, and jdrones still hasn't released a tricopter frame...
    Ethan, do you mind if I use your illustrator designs and try to fit them into Ponoko?
    I may also use some of the arch artwork from the quad and put it all together in one project that can hopefully fit two full frame kits on one P2 size job. I just need to move the arch centers from 4 notches at 90 to 3 notches at 120... unless someone has vector drawings of that already!
  • When you say "first it will be available on jDrones and after that mode widely," you mean you'll release the designs as an open source build?
    And just as a pre-tasters or teasers.. Here is first pictures of ArduCopter Tri Frame. There are few things to do with it but we are close. First it will be available on jDrones and after that mode widely.
    ArduCopter Tri frame with Tilt tail rotor
    3692227199?profile=original
    jDrones, R/C UAVs and More....
    Manufacturer of ArduCopter frames and parts. Custom airframe manufacturing, Custom design services for all your R/C UAV needs
    ArduCopter Tri frame is almost out from the door along with ArduCopter Hexa frames. Both frames follows original look and feel with some improvements.
    Tri frame is more tricky to do due it has to have tilt capability on tail rotor.
  • I have been flying a tri recently and while it is relatively easy to make your own, more kits would be nice as an option. There really are not many available that I could find when I was researching it. And of course none designed to mount an APM.
    One aspect which can be tricky is the yaw servo. But there are as many approaches as there are people flying tris, so plenty to choose from.
    Anyway I'd be interested to see a nice, inexpensive design. There are indeed a great many people flying these now, but I have not heard of many using them with an autopilot. Hopefully that will change.
  • That's a great idea Ethan, keep us updated with your progress!
