Hi guys,
I think we can use sat modem to control uav and view the telemetry data digi international was made tiny sat modem 48gm wight for data TRX and cost around 140 USD http://www.digi.com/pdf/ds_digim10.pdf
ftp://ftp1.digi.com/support/documentation/90033936_A.pdf
Pretty cool, I am not to sure but dont you need to pay satellite company to use their satellites which could get expensive?
Oh look what the FCC warning says on it.
Comment by narwhal on February 29, 2012 at 2:09am Satellite modems can be tiny, but size isn't the issue, expensive satellite networks are
Comment by Max on February 29, 2012 at 2:25am Haha good one Gary! :P
Comment by Jack Crossfire on February 29, 2012 at 2:54am Satellite communication is the holy grail. Hopefully after Google buys out 3drobotics, sparkfun, & hobbyking, they'll get the RC broadband satellite launched.
For now, we're stuck with Orbcomm. According to kiwipedia, "gaps between satellites can result in message delivery times of 15 minutes or more...To avoid interference, terminals are not permitted to be active more than 1% of the time, and thus they may only execute a 450ms data burst twice every 15 minutes."
There is a portion of the sat band being allocated for dedicated UAS command and control, along with some lower frequencies as well. Do not expect RC type command and control frequencies to be allowed to do anything other than LOS stuff. Radio regulators around the world have not had to consider UAS usage for stuff they have licensed on the basis that its being used by enthusiasts for fun. I had to get a special licence for a JR radio in the UK for a thing, because OFCOM would not accept the standard one it comes with for hobby use. It was not difficult, but had to be done.
Just one of the many elephants in the room, in fact an entire herd of them as we move towards wider acceptance.
Comment by Wouter van Verre on February 29, 2012 at 3:41am Nice catch Gary!
Comment by Tom Kent on February 29, 2012 at 12:38pm If my memory serves me correctly from a study I did several years ago, Orbcomm is a store-and-froward satellite system. When a satellite happens to pass overhead, you dump your data to it, it then will drop your data off at the next available ground station. Great for non-real-time things like tracking a shipping container or getting data from a meteorological buoy in the middle of the ocean. Not so hot for realtime command and control. If you want a satellite modem for that you'll need to go Iridium or Globalstar (LEO) or some others that have sprung up in GEO, but require larger antennas.
Years ago, before the availability of fiberoptic networks across our province here in northern Alberta, brought high speed Internet, our college did extensive testing and found satellite to be unsuitable for multimedia of any kind.
With the delay and "batching" of data, it would be likewise unsuitable for realtime control of R/C FPV, or UAV craft.
Plus, just as @Tom mentioned, our antennae were the size of sat TV from the '80s!
@Tom
It's both, it can be used in Normal Mode ("Gateway mode"), which allow [near] real time messaging (if you consider upto 3min delay). That mode is very limited and only works in major markets (does not work in oceanic environments cause of the ground station problem). Note, the sats allow bi-directional comm and thus can relay data, but I have a feeling it's not offered at the consumer level (??).
Of course, you link to orbcomm in Globalgram mode, which then messages are processed in store and forward fashion.
Note OrbComm2 was approved with much improvement, and launches were started recently.
If you need the service now, you may want this unit instead, though maybe a bit big.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
24 members
133 members
1298 members
249 members
Powered by
