Welcome Nick to the show!
This week we tried to compare the Nova's max speed to the Raptor, however a radio Tx/Rx failure occurred during the Nova's takeoff, causing a massive crash that nearly destroyed the Nova. Never use a 5 year old cheap Tx/Rx on your handmade custom airplane.
We then tried to get a max airspeed for the Raptor, however our airspeed sensor continually gave suspect readings. We decided to go back to the drawing board to consider what we should do next.
A tough week, but it was a lot of fun having Nick on the show.
More to come!
-Trent
Main Camera: Panasonic HDC-TM900K
--Raptor--
Battery: 20C 2.2Ah Sky http://www.hobbypartz.com/77p-sl2200-3s1p-20c-3333.html
Servos: T-Pro 9G http://www.hobbypartz.com/topromisesg9.html
Motor: Optima 450 2220-1800KV http://www.hobbypartz.com/75m55-optima450-2220-1800kv-2.html
ESC: Exceed RC Proton 30A http://www.hobbypartz.com/07e04-proton-30a.htmlProp: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZL07
--Nova--
Battery: http://www.hobbypartz.com/77p-sl4400-3s1p-30c-3333.htmlidProduct=6306
Servos: http://www.hobbypartz.com/topromisesg9.html
Motor: http://www.hobbypartz.com/75m42-optima450-2220-950kv.html
ESC: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
Prop: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=...
Welcome Nick! Too bad about the Nova but I think it can be rebuilt.
The worst case would be a new wing for her (using a less lethal foam cutter...)
You boys are going to get chiggers looking for parts in those woods...
Thank you for the video - real life, real hobby.
Comment by Helldesk on April 14, 2012 at 8:16am Ouch! Sometimes we hurry and make snap judgments to employ a solution or a component that in hindsight wasn't such a good idea. Kudos for publishing the results nonetheless!
Did the tape holding down the pitot tubes happen cover the small holes on the side the static tube? Perhaps that might explain the inconsistent readings.
Finding max speed would be something you do to destruction. Otherwise how would you know it's max.
Rather find the sweet spot for cruise. You might well end up with control surface flutter or some other flexing of the wing which will make things rather horrid.
Slow down, you move too fast, you've got to make the morning last
Comment by Ramon L on April 14, 2012 at 11:51pm Trent what servos you have been using on the nova?? Just to mention, If you do not have enough torque in your servos for such high speed, your control system will become unresponsive do to the lack of power of the servos to move the surface on such higher pressure. My recomendation for the raptor is that, if you are not using a servo capable of handling such pressure, dont go full throtle or you know what can happen..also seal the hinge lines with tape or transparent covering it is a great tool agains surface flutering.! By the way keep the good work coming!
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
