For decades, aircraft designers seeking to improve vertical takeoff and landing (VTOL) capabilities have endured a substantial set of interrelated challenges. Dozens of attempts have been made to increase top speed without sacrificing range, efficiency or the ability to do useful work, with each effort struggling or failing in one way or another.
DARPA’s VTOL Experimental Plane (VTOL X-Plane) program aims to overcome these challenges through innovative cross-pollination between fixed-wing and rotary-wing technologies and by developing and integrating novel subsystems to enable radical improvements in vertical and cruising flight capabilities. In an important step toward that goal, DARPA has awarded the Phase 2 contract for VTOL X-Plane to Aurora Flight Sciences.
“Just when we thought it had all been done before, the Aurora team found room for invention—truly new elements of engineering and technology that show enormous promise for demonstration on actual flight vehicles,” said Ashish Bagai, DARPA program manager. “This is an extremely novel approach,” Bagai said of the selected design. “It will be very challenging to demonstrate, but it has the potential to move the technology needle the farthest and provide some of the greatest spinoff opportunities for other vertical flight and aviation products.”
VTOL X-Plane seeks to develop a technology demonstrator that could
  • Achieve a top sustained flight speed of 300 kt to 400 kt
  • Raise aircraft hover efficiency from 60 percent to at least 75 percent
  • Present a more favorable cruise lift-to-drag ratio of at least 10, up from 5-6
  • Carry a useful load of at least 40 percent of the vehicle’s projected gross weight of 10,000-12,000 pounds
Aurora’s Phase 2 design for VTOL X-Plane envisions an unmanned aircraft with two large rear wings and two smaller front canards—short winglets mounted near the nose of the aircraft. A turboshaft engine—one used in V-22 Osprey tiltrotor aircraft—mounted in the fuselage would provide 3 megawatts (4,000 horsepower) of electrical power, the equivalent of an average commercial wind turbine. The engine would drive 24 ducted fans, nine integrated into each wing and three inside each canard. Both the wings and the canards would rotate to direct fan thrust as needed: rearward for forward flight, downward for hovering and at angles during transition between the two.
The design envisions an aircraft that could fly fast and far, hover when needed and accomplish diverse missions without the need for prepared landing areas. While the technology demonstrator would be unmanned, the technologies that VTOL X-Plane intends to develop could apply equally well to manned aircraft. The program has the goal of performing flight tests in the 2018 timeframe.
Aurora’s unique design is only possible through advances in technology over the past 60 years, in fields such as air vehicle and aeromechanics design and testing, adaptive and reconfigurable control systems, and highly integrated designs. It would also be impossible with the classical mechanical drive systems used in today’s vertical lift aircraft, Bagai said.
The Phase 2 design addresses in innovative ways many longstanding technical obstacles, the biggest of which is that the design characteristics that enable good hovering capabilities are completely different from those that enable fast forward flight. Among the revolutionary design advances to be incorporated in the technology demonstrator:
Electric power generation and distribution systems to enable multiple fans and transmission-agnostic air vehicle designs
Modularized, cellular aerodynamic wing design with integrated propulsion to enable the wings to perform efficiently in forward flight, hover and when transitioning between them
Overactuated flight control systems that could change the thrust of each fan to increase maneuverability and efficiency
“This VTOL X-plane won’t be in volume production in the next few years but is important for the future capabilities it could enable,” Bagai said. “Imagine electric aircraft that are more quiet, fuel-efficient and adaptable and are capable of runway-independent operations. We want to open up whole new design and mission spaces freed from prior constraints, and enable new VTOL aircraft
taken from here
  • http://www.aurora.aero/wp-content/uploads/2016/04/LightningStrike-V...
    http://www.aurora.aero/wp-content/uploads/2016/04/LightningStrike-VTOL-X-Plane-Subscale-Model-First…
  • First flight of their 20% subscale prototype. 324 lbs is a bit heavy, no mention if this prototype is using an all electric battery setup or series hybrid with some two stroke or microturbine.
    Aurora Press Release
    I wonder when the clones with series hybrid setups will pop up?
  • This particular VTOL UAV (LightningStrike) is in some ways a spiritual evolution of their earlier Excalibur work (a UAV featuring a center mounted tilting gas turbine with three deploying electric fans for auxiliary lift). This particular incarnation is interesting as it essentially is using a unit propulsion/wing block, which in theory allows scalable designs (there is military research interest in semi-custom "on-demand" vehicles, where a central depot 3D prints custom parts and combines with standard building block parts to create various UAV and UGV).
    Emulating the unit block propulsion module at the hobbyist level runs into the same problems as EDF though, mainly inlet design related static thrust issues.
    The more interesting program to watch is Joby Aviation's work on the LEAPtech/SCEPTOR demonstrator, and their follow-on S2 VTOL design which is a derivative of the demonstrator featuring tilt multiple electric tilting lift rotors which feather/stow and separate cruise optimised propellors/motors. This is work following on the heels of NASA's GL-10 Greased Lightning tiltwing VTOL work.
    LEAPtech Demonstrator
    S2
    NASA Langley GL-10
    ESaero is involved with SCEPTOR, and may have been somewhat involved in LightningStrike. ESaero was part of the NASA N+3 future aviation technology research studies, originally identifying a superconducting turboelectric airplane in the 767 class as feasible (extrapolating on current known technologies but not near-current). ESaero went back and looked at more recent electric motor developments, and concluded they could make a non-superconducting closing design at N+2 class (meaning near-current tech) called the ECO-150. Their N+2 design has a similar box propulsor main wing with a midspan turbogenerator. The design can be seen on the first image on their homepage image slideshow.
    ESaero
  • MR60
    For military purposes this design is failing on the huge noise it generates, not very discrete, and a huge number of motors and props that shall be too fragile and hard and expensive to maintain (think of theaters of operation with sand and or salty environments)
  • Any idea how this thick/bi wing works aerodynamically? I have tried to googled it but no luck.
    I would rather go for a larger collapsable open propellers on a single wing (aka GL-10 Greased Lightning), but perhaps EDFs are mechanically simpler.
    As they do not need all EDFs during forward flight perhaps that let them to freely turn with airstream ??? Or perhaps the are designed to run all of them with forward cruising speed?
    I like the removal of vertical tail as the vertical tail.
  • still suffers from turning into a sailing ship in VTOL mode.
