Development of a composite twin boom pusher airframe.
Tags: airframe, boom, compsite, pusher, twin
Comment by Graham Dyer on September 29, 2012 at 8:46am
Very nice, that planform does fly well, I'm on my second and thinking about a third. FWIW, found I needed about 3 deg positive incidence on the main wing relative to the horizontal stab to prevent "tuck-under"
Comment by Leo Hogg on September 29, 2012 at 8:49am
Interesting. On here the tail-booms are inclined 3 degrees to the horizontal. The wings still require laminating.
Comment by Graham Dyer on September 29, 2012 at 8:58am
What's your main wing relative to horizontal? I settled on 3 deg leading edge up on the main wing OR 3 deg leading edge down on the horizontal stab.
Some info and photos here
Comment by Graham Dyer on September 29, 2012 at 9:06am
oh, and I put in about 5 deg of dihedral, critical for nice flying properties, IMHO
Comment by Leo Hogg on September 29, 2012 at 12:18pm
there will be no dihedral angle for ease of construction. I'll check the other figures.
Comment by M Davis on September 29, 2012 at 9:00pm
Where can i find a kit like this ?
Comment by Ravi on September 30, 2012 at 1:13am
what is the exact type of foam used for the core of the wing. what type of surface covering you have applied on the wing surface. the frame is very interesting because of simplicity of construction. what is the wingspan.
Comment by Leo Hogg on September 30, 2012 at 2:30am
Hi all.
Just a few technical details.
Its a Clark Y section (still hard to beat) set at 3deg for a cruise Cl of about 0.6. I will start off with the tailplane at -2. Span is 2.2 meters, chord 290cm. The Fuselage was made by carving a Styrofoam plug, covering in packing tape, then 1 layer (2 in places) of carbon/Kevlar and vacuum bagging. The foam was then hacked out of the wing join cavity. Being an external layup the finish is a bit wrinkly from the bag and its a pain sanding Kevlar as it gets fluffy (I had forgotten about this). Lesson learned- next time finish with a thin layer of glass.
The wing foam is just a pink/orange version of Styrofoam (made in Italy I think), cuts very nice. I was intending to layup 2 layers of 170g glass but am checking my bank to see if I can use 1 layer of 200g carbon (like the tail bits are), should save about ½ kg. No spar as such, just some 50mm UND carbon tape. Than the usual Mylar(subtitle) and vacuum bag.
Am toying with the idea of making moulds for the Mk2 and would probably go a little smaller (2m of less?).
Comment by Richard on October 1, 2012 at 6:04am
Very nice build you have there, thought it rude not to comment... As your specs are so similar to mine (2.2m wingspan, 300mm chord)  - I thought i'd post a pic... !
Good luck with the maiden..
Comment by Harry on October 1, 2012 at 10:30am
I like pushers of single or twin boom.  As for your lost foam technique, I made lost a foam pod once and forgot the packing tape part.  The pod had a hole for pouring in the acetone and the boom exit was where I let it all drain.  I got one interesting benefit from not using the tape and that was the foam dissolved mostly and left a crusty glue like film on the inside.  This foam crust added a lot of strength and durability.  I still smashed it up in a crash, but it is very repairable and will fly again one day.
Comment
