Here's a little vid of my DIY WKM Heavylifter Hexa
Please Enjoy!
Jacques
Great Video Jacques, it all looked very smooth...... :)
Regards
Maritn
Comment by Jonathan M on July 7, 2012 at 7:26pm Cool video. What props are you using on your setup? Also, are you using the CS isolator schemed to mount your gimbal to or something else?
Comment by SynDrones on July 8, 2012 at 8:28am Thank u Martin!
Comment by SynDrones on July 8, 2012 at 8:31am im using the Xoar 14x5 and no im not using the cs dampening plate...made my own plate wich is held in place by 6 vibration dampers (tese small black rubber barrel kinda thingys with m3 thread inside and m3 treadend comming out of it) seems to work fine...not suffering from ant high frequency vibrations or anything like it...picture is super steady :)
Comment by Jonathan M on July 8, 2012 at 1:13pm Thanks for the info! Very cool. I have used those grommets and similar ones with great success, but I generally use them in compression rather than tension. Cool to see they are working for you! If you don't mind me asking, what is the length of your landing gear. I have a similar style hexa (non-CS) with similar gear but not sure how long they should be for the CS gimbal (one gimbal that I am considering). Thanks
Comment
1297 members
79 members
183 members
690 members
Powered by
