I definitely recommend this excellent and super fun aircraft E-flite Convergence Vtol. Why? go ahead, after reading this E-flite convergence vtol review you will know the reason.
Unboxing
There are one boboy convergence vtol BNF, two pair propellers, two vertical fins and one user manual in the foam box.  The quality of the E-flite convergence vtol feels pretty good as is expected from Horizon Hobby.
Assembly
Install the vertical fins: Install the vertical fins on the fuselage using two screws per side.
Install  propellers:The main propellers are labelled near the hub with an “R” and an “L” to show on which side they should be installed.
Install battery:Install the fully charged battery in the battery compartment. Secure using the hook and loop strap. Connect the battery to the flight controller. Refer to the Center of Gravity section to ensure the model balances at the
recommended CG.
Install FPV system
Items required for FPV system installation, there are camera,video transmiter,antenna and video monitor with headset or goggles.
Flight test
For your first flights with the recommended battery pack, set your transmitter timer or a stopwatch to 6 minutes.
To transition to airplane flight from multirotor flight, change the flight attitude switch on your transmitter to the airplane flight position. The throttle will increase slightly and the motor nacelles will rotate forward in three stages to the airplane flight position.
To transition to multirotor flight from airplane flight, reduce the airspeed, change the flight attitude switch on your transmitter to the multirotor flight position and stability mode for landing.
Comment
