Finally got my 'Tronics from the store
Up to the assembly work !
The boring work completed after a couple of minutes:
Soldering the magnetometer:
Had to solder the GPS to the header because the store didn't have the GPS cable
GND to GND, 5v to VCC,
TX on the APM to GPS IN
RX on the APM to GPS OUT
connecting...
that makes a nice sandwich !
and...
checking the reading....
SUCCESS !
Only the GPS is not outputting data...
I've checked in the terminal sending "S" during flight mode, but all the numbers in the end are 0.0000
the led on the GPS is constantly on after certain time... dont know what this means.
maybe it doesn't get enough satellites from my window ?
Comment by Chris Anderson on March 27, 2011 at 11:36pm
Yes, it's hard to get GPS lock inside
Comment by ARHEXA on March 27, 2011 at 11:45pm
I've read somewhere that some codes are not compatible with some versions of the GPS...
the GPS says MEDIATEK-V12. i'm using the RC2 code - are they good friend ?
does it need some special config in the code to turn the GPS on ?
Comment by Chris Anderson on March 27, 2011 at 11:47pm
No, don't use RC2.  Use the ArduPirates code instead and select MTK16 as your GPS.
Comment by ARHEXA on March 27, 2011 at 11:52pm
OK,
I'm going here http://code.google.com/p/ardupirates/downloads/list
what should i download ?
and to i just put it in the arduino sketch dir and upload it like the RC2 ?
Comment by ARHEXA on March 28, 2011 at 12:32am
ok
now this give me
i cant find the coordinated (it should be 32....,34....)
#################### GPS LED BLINKING ###############################
0,3,0,-1,0,8,29,0,1040,1040,1040,1040,-29,39,421,1.4329,0.1375,0.9905,65,201,-363
0,3,0,-1,0,10,29,0,1040,1040,1040,1040,-29,41,420,1.5552,0.0156,0.9999,43,204,-374
0,2,0,-1,0,11,28,0,1040,1040,1040,1040,-29,41,421,1.4924,0.0783,0.9969,54,186,-381
0,3,0,-1,0,11,28,0,1040,1040,1040,1040,-29,41,422,1.5049,0.0659,0.9978,50,183,-365
0,3,0,-1,0,12,28,0,1040,1040,1040,1040,-30,41,422,1.4327,0.1377,0.9905,63,202,-349
#################### GPS LED CONSTANTLY ON ###################
0,2,1,0,0,-25,119,0,1040,1040,1040,1040,31,297,324,-0.7893,0.7044,-0.7098,329,-336,188
0,2,1,-2,0,-25,119,0,1040,1040,1040,1040,32,298,324,-0.7810,0.7102,-0.7040,321,-327,192
0,2,2,-2,0,-25,119,0,1040,1040,1040,1040,31,297,325,-0.7696,0.7182,-0.6958,335,-316,168
0,1,1,-1,0,-25,119,0,1040,1040,1040,1040,31,297,325,-0.7855,0.7071,-0.7072,329,-321,166
Comment by ARHEXA on March 28, 2011 at 1:08am
I've just spotted that "0.7071" appearing in the command terminal is part of the exact latitude i'm at.
but no signs for pars of the longitude (should be 34,50,13)
Comment by Kirill on March 29, 2011 at 3:47am
I had the same problem. I got only ............................ symbols and not any more.
I solved this problem by changing "GPS_PROTOCOL_MTK" with "GPS_PROTOCOL_MTK16" in apm_config.h.
My gps works even in the house not far from the window - about 4-5 meters.
Comment by ARHEXA on March 29, 2011 at 4:29am
solved by sending '4' instead of 'S'
Comment by Rebel K on March 29, 2011 at 9:23am
@ AR
Could you please tell me how you've got those graphs (Outputs), that show the Roll, Pitch and Yaw.
Thanks !
Comment by ARHEXA on March 29, 2011 at 10:49am
It's on the configurator, just select 'raw sensor data'
Comment
