Info from their website:
EXPLORER is the development of MAJA for a bigger UAV with more payload and shorter runway. The both motors are very powerful and quiet and gives EXPLORER many application possibilities. The used materials EPP and Coroplast exhibit a small weight and are extremely durable.
EXPLORER can be used for the following areas:
- Aerial photography
- Surveying
- Air observation
- Environmental protection
Wingspan: 220 cm
Length: 140 cm
Weight without LiPo: 2,5 kg
Wing loading: ~ 40 g / dm ²
Payload: 2,5 kg
Time of flight: ~ 1/2 h
-MADE IN GERMANY-
Basic Kit Price $374.99
Twinstar on steroids, I like should be a great platform.
Yeah, I would really really like a twin for the perceived "able to get back home if an engine fails" factor, though I'm not sure it's really true?
But the price on that is... ouch.
Comment by Francois Sabourin on June 11, 2012 at 8:48am Back in 2010 the Paparazzi autopilot successfully tested an adaptive control loop compensating for the partial loss of a wing and the complete shutdown of an engine on a Twinstar. Its an impressive video highlighting that it is technically feasible.
My own experience in manual mode with my Seawind EP retro-fitted with in-line twin engine contra rotating props validates the "get back home if an engine fails" theory. In April, on my second flight with this power plant the collet adaptor let the front prop fly off on the takeoff climb out. I was able to bring the plane back to an uneventful water landing.
I installed this twin primarily to increase thrust to weight ratio to compensate for the weight I fly at, and to eliminate torque roll and P-factor. Engine redundancy was not high on my priority list. In terms of failure modes, there are lots of variables, but I suspect with my setup a stock APM firmware would probably handle the loss of one motor, baring in-flight fire. I really hope I don't find out.
"..and shorter runway." ??
It must be a translation error.
This is definitely a function over form design.
Comment by John Stuart on June 12, 2012 at 1:47am Coroplast - are you sure? It degrades and disintegrates from UV exposure, its not a robust material at all.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
207 members
24 members
52 members
719 members
Powered by
