FPV airplane flying 120 minutes and 100 km range with an 6S6P NCR18650GA battery pack
Design, dimensions and technical specifications.
  • Cell count: 36 (same rank cells)
  • Cell type: Li-ion Panasonic NCR18650GA 3.6V 3.5Ah 10A
  • Series-Parallel-Connected Cells: 6S6P
  • Current capacity: 21Ah (21000 mAh)
  • Voltage (nominal) 22.2V
  • Energy capacity: 466Wh
  • Power: 1332W
  • Maximum continuous discharge current: 60A
  • Pulse (10sec): 80A
  • Maximum allowable charge voltage: 25.2V
  • Discharging end voltage: 16.2V
  • Charging current (CC): 10A (for maximum energy storage)
  • Weight: +/- 1800g (including wiring harnesses, connectors & covering)
  • Physical dimensions (distance between cell pack edges, excluding harnesses)19.5 x 6.9 x 7 cm
  • Gold plated discharge connector (custom on order): XT90 / XT90s
  • Discharge wire type: Multi-strand 12AWG Flexible Shielded Discharge Cables (EMF Compliance)
  • Discharge wire length (pack to connector end) +/- 100mm
  • Balance plug: JST-XH 7-pin
  • Balance wire length (pack to connector end): +/- 70mm
Performance:
FPV MTD airplane flying 120 minutes and 100 km range with a full charged battery. Still remained 25% from battery capacity at the end of the flight.
Avionics & power supply: Pitlab Autopilot, Pitlab Buddy Flight, Dragonlink Advanced v3 Slim and CMEC 6S6P NCR18650GA lithium-ion battery pack.
Camera: Xiaomi YI 4k + Mini 3d ProGimball.
Courtesy of Sander VDL
See full video here:
https://youtu.be/33T-gcz8amE
Comments are closed for this blog post
Comment by Cristian Miuta on December 4, 2017 at 1:14pm
