FPV Ground station integrating Brix
3689604439?profile=original
Hardware:
Computer: Gigabyte Brix i5 4200
Primary video: ReadyMadeRC 11" monitor
Secondary video: Fatshark Dominator goggles
DVR: Lawmate 500EVO
Receivers: Lawmate 1.3 gHz (one tuned, one not)
Diversity: Eagletree EagleEyes
Case: Pelican 1450
Tripod: Dolica proline 64"
Tripod base: Manfroto
Having flown FPV for about three years now I got a bit tired of bringing a netbook with me just for programming and telemetry when I go out to the Italian countryside to fly in the weekend. While light, my netbook was not powerful enough for basic video editing, the battery ran out too quickly, it required an adapter, and was frankly was just another thing to carry around. So to make my life a bit easier I collected various parts and built my very own groundstation into in a Pelican 1450 case and it's been all smiles since then!
The picture above is from a couple of months ago in the Sibilini mountains here in Italy. It was a lovely place to fly, given the views and the wide-open spaces.
Adding a Brix to the box
What may be a bit different from other ground stations I have seen is that I have integrated a Gigabyte Brix (i5 4200) into the case to have just a bit more power at my disposal. I use a ReadyMadeRC monitor to switch between the HDMI video/audio from the Brix (for pre-flight and telemetry), and switch to the video while flying (EagleTree Eagle Eyes for diversity). I have a Lawmate DVR integrated into the top panel to be able to record everything and a Fatshark Dominator headset mostly for the enthousiastic onlookers (often local pilots) who want to check out how emersive FPV can be!
Power conisderations
The biggest challenge I had was getting all the components to "place nice". The setup runs off of a 6000mAh 3s LiPo, but the receivers and screen need 12V, the DVR runs on 3.7V and the Brix runs on around 18.3V. I ordered a handful of switches, a couple of step-up/down regulators from Pololu, and a hefty variable regulator for the Brix, and started soldering everything together. I have to say the setup works very well, the signal seems strong, images crisp and even with the computer running there is no EM intereference.
Running off of a LiPo is convenient but since the setup draws less than 5A, using a 12v lead starter battery is a safer alternative. The Brix uses the largest share of the amperage (3A using LXDE, a bit more using Ubuntu linux 14.04).
Software
I am running Mission Planner 2.0 for Linux and I have all the usual Windows-based utilitities in a Virtual XP environment, should I need them.
If anyone has any questions, do let me know, and I'd be happy to provide any more details people are interested in!
PS. My immense gratitute to the crews behind the Mission Planner software and the APM and Pixhawk hardware. None of this would be possible without you guys!
  • Dear Daniel, SG and Hugues, thanks for the comments! I havent put together a build blog as yet, but I have been looking for an excuse to make one ;-)
    I have been using the ground station for a while now and I have some lessons learned that may be of use. If you'll give me a couple of days I'll take some picture, organize my thoughts, include the svg files I used for laser cutting the top panel, make note of all the part numbers and links, and provide any other information you might find useful.
    Do let me know what you are most interested in, and I'll use that as a guide for putting together the log!
    Best,
    Robert
  • MR60
    I would love to see your building details with pictures. Do you intend to publish a build log? Thx
  • Very clean setup, I love it!
    Would you be willing to show us how everything fits together in the case?  Do you have a build log?
    Cheers!
  • Awesome setup!
  • Ciao, JC I did indeed, but it appears i accidentally posted a draft message. I'll finish it now!
  • Hello Roberto,
    you say "integrating Brix" : does it means you have a Gigabyte Brix mini computer inside your FPV groundstation?
    Which model did you choose ?
    Also could you describe more in details your hardware inside the pelican box
    - I can see you are using a readymaderc FPV screen
    - could you describe your switches, power supplies used and provide some simple schematics ?
    Grazie molto
    Ciao,
    JC
