Hello ,
Now I made a little video of my
FPV monster!
Peter
looks great!
Clean looking build. The motors are at different heights, do the props overlap?
Comment by Peter Koppendorfer on November 5, 2011 at 1:39am Hello and thanks,
The motors are on two levels!
I have made tests to determine the efficiency
when I use small three-bladed propeller, I have a poorer efficiency by 20%!
The PID settings are a bit harder than a normal quad but the size is a big advantage.
I have now flown the little monster with different
Electronics .
(Easy to use) KK-copter
Mikrokopter (expensive)
Ardukopter (all options)
Peter
Comment by Ellison Chan on November 5, 2011 at 11:27am I like the overlapping props. Can you explain a little about the PID settings needed? I would like to do the same thing.
Comment by lucas loh on November 6, 2011 at 11:06pm yeah i like the overlapping concept its simply shrink the size down. btw peter what material did you use for the frame?
Comment by Peter Koppendorfer on November 6, 2011 at 11:10pm Hi,
i used 2mm GFK
Peter
Comment by lucas loh on November 6, 2011 at 11:29pm nice! thanks peter
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.677 members
1284 members
24 members
4 members
8 members
Powered by
