Wanted to give you guys a heads up on this RX I have been waiting for for quite some time. The FrSky TFR4 - w/ normal servo connections it is a 4ch RX, but when set up as a PPM out RX you get 8ch out via PPM along w/ RSSI, and it is very small. Perfect for use wherever a PPM RX is needed.
Enjoy,
Bob
Warning, this receiver is for Futaba FASST system, not for own Frsky system ACCST !
It is one way only, no telemetry.
Telemetry (link qty and Rx voltage) is available on the D4FR receiver for their own system:
http://www.himodel.com/radios/FrSky_2.4G_4-channel_Two-way_Micro_Re...
That receiver is good for Arducopter32 it support ppmsum receiver . 1 Wire 8 Channel.
My idea is to implement also the possibility to have two reciver Master and Slave as failsafe.
Actually I'm doing my test with Jeti. It work fine .. FRSKY support telemetry ?
Best
Roberto
