I flew AC 3.0 (rc5) at Sparkfun which required me to rethink my vibration dampening strategy. In other words I had to go from no strategy to something very robust. If you want to fly 3.0 in any AP mode you'll need to consider at least some of these methods. Once upgraded, my copter was able to hold a 1 foot loiter box with the crappiest RCTimer props/motors they sell without issue.
Here was my shopping list:
http://www.rangevideo.com/accessories/vibration-mount.html
http://hobbyking.com/hobbyking/store/__8999__peel_n_stick_foam_tape...
http://hobbyking.com/hobbyking/store/__26457__Anti_Vibration_foam_O...
http://store.3drobotics.com/products/m3-vibration-damper
I attached the latex foam to the vibration mount with super glue which worked nicely. Adding the dollar coins with super glue under the floating vibration mount also worked well.
Even with motors vibrating so much that they looked burry, it still held a great loiter.
Jason
Distributor
Comment by Dany Thivierge on June 17, 2013 at 12:09pm
I also go overboard Jason!  :)
Moon Gel works wonders, rubber spacers also get some vibration out making the electronic tower better insulated from the rest. 2 X Double side tape was my pre 2.9 ideal choice, still works great in conjunction with the other materials.  I think the key is diversity in absorption material (unless someone just perfectly dial-in the material we need for all frames/conditions) hehe
So yeah it works great! :)
Dany
www.CanadaDrones.com
Comment by Stone1295 on June 17, 2013 at 12:30pm
Any chance the 3DR store will begin to sell things like Moon Gel or the Great Planes Rx foam?  It seems to be a great opportunity to tie in some sales.
-Mike
Comment by Jack Crossfire on June 17, 2013 at 12:47pm
The most important preparation for a new Arduproduct is rebranding the whole thing as Hobbyking & selling it at 1/2 the price with some chinese spelling.  Would be interesting to measure its accuracy at 3pm in the city, between some highrise office buildings.
Comment by Daniel Allen on June 17, 2013 at 1:33pm
So why does AC 3.0 suddenly need so much dampening? Is there more information on it?
Comment by Jason Short on June 17, 2013 at 2:35pm
AC3.0 uses accelerometers to maintain absolute position. High frequency vibes will interfere.
Once you get the vibes taken care of. 3.0 will surprise you with the performance. I'm sure Randy will do a post about it soon.
Jason
Comment by Thomas Robinson on June 17, 2013 at 4:36pm
Great information here! Thanks for sharing guys!
Comment by Maxime Carrier on June 17, 2013 at 5:51pm
I did nothing to damper vibration, I didn't even try to balance prop but it is super stable anyway and altitude hold work perfectly.
I can't imagine what will happen if I put this stuff on my tri ;)
Comment by Jason Short on June 17, 2013 at 6:05pm
I did slightly less on my hexa, but I'm mostly afraid what will happen in high winds. When the motors fight and the blades start flapping, new frequencies of vibrations can appear out of no where. I don't want to take any changes as I will be using these soon for long haul flights.
Jason
Comment by Maxime Carrier on June 17, 2013 at 6:13pm
I admit I have never though about frequency change, maybe I should put luck on my side, I'm doomed since I'm flying RC :D
While hoovering during my last flight It worked great but suddently one motor stopped without any warning leaving the tricopter plumet to the ground, just hoovering no manoeuver. Not a big deal, I just need to print annother frame but since this incident I consider the possibility to switch to hexa for redundancy.
Comment by Gary McCray on June 17, 2013 at 7:52pm
On my DJI 330 and 450 FlameWheels, a 3/4" square of Kyosho Zeal Gel under each corner of APM on one and PX4 on the other secured with foam under a Velcro strap which is loosely tightened yields ~0.1G vibrations which are more than adequate.
Moon and Alpha Gel also work fine.
I have used the the four O-ring suspension mount system too which can yield nearly as good results but requires careful "tuning" of O-ring cross section and tension.
It is also important to provide a bit of a strain relief loop in the wiring to prevent vibration transferred through the wires.
For the motor and prop balancing proponents: Of course that can help, but unless you are a fanatic, you still need the above types of anti vibration flight controller mounting to get into the best range for version 3.0.
Which is the less than 0.2G vibration (less than 2 (shown in meters per second with Earth Gravity being 9.8 (look at Z axis)) as measured at the accels on the RAW or IMU log).
Comment
