So I thought I would get some close up shots and higher res video to show some of the finer details of the launcher. Like most things in this hobby it didn't go to plan as when i went to take off the Esc and Motor smoked themselves, so no launch, and after borrowing a friends motor found that he uses 4mm motor connectors and I use 5mm so no go there. Anyway here are some pics.
set and ready to go,
front pulley and release trigger.
Front Legs.
Ram about 1/4 out.
Front trigger about to release.
Trigger Realised.
regards Richie.
Comment by Vladimir "Lazy" Khudyakov on June 17, 2012 at 9:48am Why you not use rubber band instead of pneumo?
Yep, bungee would be much simpler. Get rid of the wheels, they are drag. I give that airframe 50 launches to distruction.
Comment by Michael Pursifull on June 17, 2012 at 1:08pm
Comment by Michael Pursifull on June 17, 2012 at 1:09pm
Comment by Richard Unwin on June 17, 2012 at 2:22pm
Comment by Michael Pursifull on June 17, 2012 at 7:25pm Thanks Richie. Do you know how much, if any, the AoI is for the wing (relative to the landing gear?)
Comment by Richard Unwin on June 17, 2012 at 9:32pm Mike, its a flat bottom wing and I havent measured it but it looks to be inline with the wheels, it would be easy enough to change the angle of attack by moving the brackets on the trolley frame, I have tried to keep it as simple as possible and allow changes for different planes to fit on the trolley frame, my other two planes have similar UC but of course not quite the same dimensions so each wheel platform is well oversized to cater for the differences, if i progress to another style of plane or one with a UC i can quickly make another trolley, i might also remake this trolley lighter to get it moving faster with the same energy levels.
richie
Comment by Kim Skatun on June 17, 2012 at 10:40pm Where did you get the parts for the ramp?
Kim
Comment by Michael Pursifull on June 18, 2012 at 2:01am Looks way safer than the one I built with high start rubber. Too much energy stored up just before launch. I estimated 40 lbs of force. I think your idea is great, I'm going to have to build one of these.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1288 members
682 members
182 members
51 members
83 members
Powered by
