Hobbyking FPV Transmitter & Video Camera 1/3-inch CCD camera
Just found this on the Hobbyking website: FPV Transmitter & Video Camera 1/3-inch CCD
camera
for US$ 39.17
Compatible with most 2.4Ghz video receiver systems this FPV camera and transmitter system is very versatile as well as light and very small.
The camera uses a quality glass lensed SONY CCD camera system.
Included:
1 x Sanyo CCD 1/3inch Camera
1 x Voltage Regulator
1 x Micro Light Weight Video Transmitter (100mW)
Camera specifications:
CCD SONY 1/3 CCD
Horizontal Resolution420TV Line
Minimum Illumination 0.01LUX/F1.2
Electric current 80MA
DSP+CCD CXD3142R+405AK
Size 38mm*38mm
FPV Tx Specifications:
Power: 100mW
Voltage Booster: 3.7v -> 12v
Weight: 8g
Channels: 4
Comment by Mark Colwell on May 25, 2010 at 7:49am
$40 for 2.4 ghz, 100mw Tx and a decent low light camera with a voltage boost to run on a single lipo, I will bet that stated tx power is close to actual rf output power.. I got their pan & tilt kit for $7, a nice unit..
Comment by CrashingDutchman on May 25, 2010 at 7:52am
I checked and I think that the dimensions of the camera (38x38mm) are just a tad bigger that what the pan/tilt accepts (36x28mm).
Comment by Mark Colwell on May 25, 2010 at 7:57am
Darn, I will have to make a longer base and tilt plates from 1/16 plywood to make it work..
Comment by Tedro on May 25, 2010 at 8:02am
Can someone help the newb with a few questions... 1) Will I be able to hook this up to my Blade SR? and 2) What is needed on the PC side to view the live video feed?
Comment by Xander on May 25, 2010 at 8:14am
Can anyone recommend an inexpensive receiver to go along with it?
Comment by CrashingDutchman on May 25, 2010 at 8:23am
@Tedro: If your Blade SR can lift some extra weight (8 gram for transmitter, not sure about camera - is not in specifications) it would probably work. Let's say that camera weigth 50 gram, can your Blade carry an extra 60-100 gram?
On the PC (or TV) side you would need a video receiver that works at 2.4Ghz (HK says'Compatible with most 2.4Ghz video receiver systems' in the description of the product). In addition, if you want to display the picture on a PC, you would need something to grab video, something like this: http://www.dealextreme.com/details.dx/sku.5707
Comment by CrashingDutchman on May 25, 2010 at 8:26am
@Xander: Please not that I have not tested/verified the following receiver to work with the product discussed here. You will have to contact both RangeVideo and Hobbyking to be sure it works.
The following COULD work (US$ 50): http://www.rangevideo.com/index.php?main_page=product_info&cPat...
Comment by Sgt Ric on May 25, 2010 at 10:50am
Thats an amazing price!
More than $ 100 bucks cheaper than most.
I would wait for more feedback from users before trusting it with an FPV plane!!
Comment by OpticalFlow on May 25, 2010 at 5:11pm
A camera that looks the same and has the same specs has been available on ebay for $25 incl. shipping for a while now. Also, this is not the only cheap 2.4 GHz TX. Have a look on the FPV forum on rcgroups for alternatives and you see that there are several options in this price range.
Comment by Chris Anderson on May 25, 2010 at 8:06pm
Any thoughts on whether this can be used alongside a 2.4Ghz RC system?
Comment
