Hobbyking 's new PPM Signal Mixer for their Head-Movement-Tracker Gyro.
Hobbyking release today a PPM Signal Mixer version B for
their Head-Movement-Tracker Gyro. This will help people with entry level Futaba transmitter to use the HT. Basically, from what I understand from the description, it adds channels to the ppm stream generated by your transmitter. If your transmitter has 6 channels, it becomes an 8-channel TX (you need a 8 channel receiver to really use it, of course).
From the website:
PPM Signal Mixer is specifically designed for those who own low end Futaba transmitters (such as the 6EX), allowing you to also use the head movement tracking system. And even can be used with JR
transmitters. (soon available)
This version B is designed for 6EX transmitter which comes with 8 channels receiver.
Just connect the PPM signal mixer inbetween the Advance Head-Movement-Tracker Gyro and the Transmitter and PPM signal mixer will map new channels special for X-GYRO 1000 via the transmitter.
Then it maps 2 channels, and put them after the transmitter channels,
now it’s 7 CH and 8 CH, that ‘s why you need a 8CH receiver. Connect the
servos to 7CH and 8CH.
Note: Only works with Futaba transmitters.
Spec.
Weight: 4g
Voltage Supply: 8V-12V
Comment by Tim McMahan on May 18, 2010 at 10:18am
I have a JR radio with the Corona 2.4ghz hack mod(also at Hobby City). I wonder if this mixer can get soldered into the ppm stream where the hackmod hooks up?
Tim
Comment by CrashingDutchman on May 18, 2010 at 10:33am
The product page on the Hobbyking website says that a JR version will be available soon. I hope this helps? If not, you could try to contact Hobbyking Live Support, they are very helpfull, maybe they can help.
Comment
