  • Could an hexapod be used for Camera Stabilization... instead of the gimbal ?
  • Can anyone tell me more about this hexapod being used? i.e which company it's from and how much it might cost??
    Electronic (digital) image stabilization only has some hard limits that you cannot get around, like motion blur caused by quick camera movements. The best approach is a hybrid system where you combine optical (mechanical) and electronic stabilization. Typically found in the semi-pro range of camcorders.
  • @mP1 ... I take your point, however, I thought the BeBop was doing a variant on the 4K-for-2K approach - oversized sensor with the image "stabilised" by cropping in to the image, which may require less CPU processing?
  • mP1, I have a Sony AS100V camera, that does do electronic image stabilization internally.  It does work.  Sort of.  It helps, but it's not perfect.  You still need a good gimbal.
  • I like it!
  • @David: I highly doubt the BeBop has real time digital stablisation. If Adobe Premiere on a fast multi core machine cant do real time stablisation, then theres no way a lesser CPU can.
  • Chris, are 3DR exploring the digital stabilisation option as per the Parrot BeBop?
  • a 3 axis tarot would be great!
  • nice machine, do you know why tarot is not releasing the 3 axis, i love my tarot 2d  but im waiting for the 3 axis. For me tarot is the best gimbal, you can buy parts an fix it in case of damage, the other brands not
