3689408475?profile=originalGood clear explanation of the power side of a brushless motor control and how to build one here. Stay tuned there for a second post on the processor/code side.
Hackaday's description:
He constructs everything on protoboard from components he acquired at RadioShack in order to demonstrate the ease of sourcing parts and building a brushless motor driver.
While he skips most of the theory behind brushless motor control itself, he does touch on the signaling these motors require for movement as well as how motor position is determined. Specifically, he expands on how half-bridges can be used to create the sine wave signaling required by a single motor input, as well as how three of these can be combined to drive a brushless motor.
  • this controller is much simple .. cannot work fine in high rpm or high toque situation because it not have any feedback(BEMF)
    It only work in open loop.
    Without this the eficiency is very low.
  • This is great!! I got some brushless motors thanks to dan and I am building an ESC of this nature (I'll beef it up for higher currents!) for the Flying Thing: http://diydrones.com/profiles/blogs/flying-thing
  • AR.Projects this is a demo not a product. The theory can be stretched in any direction to components holding the same setup. So building one like the manufacturers is as hard as going on digikey.
    Excellent find Chris
  • Interesting that he got better efficiency as the waveform approached a sine wave.  Makes you wonder if the HobbyKing ones are as efficient as possible. Now it needs over current protection, deglitching, loss of signal detection, automatic shutoff.
  • TIP125 ? 5A max load ? you kidding ?
    I can't think of a real application unless for testing. and still, this is not even a MOSFET
    take for example IRF3205, it has up to 80A, 0.008 Ohm. not counting you can also parallel them.....
    also i really like the SMD mosfets on the commercial ESC, they allow a much smaller and lighter device.
    but for ground vehicles sure the DIY with the RIGHT MOSFETs could be great !
