Hi, my name is Jordi. I am currently building the first Glowduino prototype, and would like to gauge the interest level in the community. I guess I should tell you what it is.
Glowduino is an Arduino-compatible LED controller board for use on multicopters. It utilizes a TLC5947 to provide constant-current sinks for 8 separate common anode RGB LED strips. In addition, Glowduino can be programmed to react to different sensor inputs or to information from your Ardupilot. For example, you could use this board to control navigation lights on your quadcopter, or control different status lights, etc.
Now here's where I need your help. There are a few things I need to know before I embark on this project. First, are you interested? Second, how much would you be willing to pay for this? Currently I'm thinking maybe in the $40-50 range. Lastly, do I need a USB vendor ID? This will be published as open-source hardware, and uses the FT232RL FTDI chip. If I do need one, is there any way I can get one for a bit less than $2000?
Thanks for reading, now here are some specs and photos.
- Brains: ATMEGA328 running Arduino bootloader (Arduino compatible)
- FT232RL for communication via USB
- TLC5947 for driving the LEDs
- 12V 3A regulated LED power supply
- 24 constant-current sinks
- 6 analog inputs (A0-A5)
- Header for expansion for more outputs (future)
- Prototypes will be from OSH Park, so purple :p (let me know if you know of a better option)
- RoHS Compliant (I think...)
- 4 status LEDs (TX, RX, ON, and L) and 2 buttons (Reset and Mode)
- Comes preprogrammed with several awesome modes!
- Powered from 2S to 6S Lipo
- Small-ish at 2" x 2"
- No mounting holes, sorry (no space...)
- Yeh!
Looks cool! How does it compare to the Jdrones IO board, which is optimized for MAVLink?
Comment by Jordi Orlando on August 5, 2012 at 11:17pm Hi, thanks! As of now I have yet to write the firmware, but it would be awesome if it was MAVLink compatible. However, I don't know much about MAVLink and how I might do that, so if you or anyone else had any advice it would be much appreciated.
I guess my question is, what does this do that the Jdrones IO board does not? It's also Arduino-compatible and is already available for $16.
Comment by Jordi Orlando on August 5, 2012 at 11:40pm Good point. This has 24 outputs, as opposed to 6, and a regulated 12v supply, but I do see what you mean. Even if there is no interest, It does what I need it to do, and it's my first attempt at something like this :p Thanks!
Comment by Jordi Orlando on August 5, 2012 at 11:43pm Oh sorry I forgot this in my last comment, all 24 pins are PWM.
Very nice to see a muliplexed board that offers signals to the processing chips in coordination.
This is what embedded design means.
Comment by Jordi Orlando on August 6, 2012 at 5:35am Thank you!
Comment by Mike on August 7, 2012 at 4:54am Since you are planning to use the FTDI chip, check out whether to use their default product and vendor ID. To see if this option fits with your overall plan, follow-up with reading this FTDI technical note. All the best.
Comment by Jordi Orlando on August 8, 2012 at 5:52am I think I should be able to use the default VID and PID, thanks!
Comment by Jonathan Lederer on August 14, 2012 at 3:15am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
693 members
24 members
51 members
1298 members
Powered by
