jDrones News: MultiMount, Multi-Arm motormount for multicopters
jDrones News: MultiMount for multicopters.
We are proud to reveal another exciting new product from jDrones. We have been working hard and long with this new product and now finally it is available to all people who need highend mounts for their multicopter needs.
Mount has been designed to use with several widely used arm types. It can be used with round tubes of 10mm and 12mm of diameter. Is also fits on all 10, 12, 15mm square tubes.
Mount have rubber cushions that will make your motors run smoothly and silently. All normal motors that have so called X mount adapter (40mm end-to-end) fits on this mount. First you mount your motor on it's adapter and then adapter mounts on top of MultiMount cushions.
You can also use it on coaxial setups as shown in following picture
For technojunkies we have cool looking installation manual (thanks to Max Levine). Manual that is really clean and easy to follow, it just cannot get any simpler than this.
MultiMount specs:
  • Fits on: Round tube 10, 12mm / Square tube 10, 12, 15mm
  • Material: CNC Milled aluminum
  • Vibration dampening: Custom neoprene rubber
  • Motors: all motors that have X mount adapter with 33mm hole spacing (most of them have)
  • Weight: 17gr
  • Size: 35 x 35mm
Set Includes:
  • 4 x custom rubber grommet
  • 4 x custom alu inserts
  • 4 x M3*12 washerhead screws
  • 4 x lock washers
  • 4 x M3 nuts
  • 2 x M3*12mm screws, Black
  • 2 x M3*20mm screws, Black
  • 1 x MultiMount upper block
  • 1 x MultiMount lower block
You can get them from jDrones Store: MultiMount MMSET2
Design by: Max Levine & jDrones
Tags: Anti-Vibration, ArduCopter, CNC, Coaxial, HexaCopter, Milling, MotorMount, MultiCopter, MultiMount, QuadCopter, More…jDrones
Comment by Chris Anderson on June 4, 2012 at 7:45am
They look gorgeous and very useful (great job with the graphics, too, Max). Ordered!
Distributor
Comment by Dany Thivierge on June 4, 2012 at 7:46am
I've been testing these too and let me tell you that they are very nice!
Feels very light and sturdy. these ones will not crack compared to the "plastic" ones (but they are more expensive... so far I cannot see any fatigue or stress on the washers or any parts.  I really like them!
Very well done Jani! I know it took quite some time to get there and how perfectionist you are.  But this is finally available!  (yes I will stock them also in CanadaDrones inventory)
Again Nice work Jani and Max I already told you but I really like the illustration!
Dany
Comment by Tsahi Mizrahi on June 4, 2012 at 7:49am
Nice job looks good.
I would say that there is need for 13x13 square tubes as thay are very common, price is a bit high.
Comment by sergei lupashin on June 4, 2012 at 7:51am
Nice. Suggestion: get rid of the nuts/washers and use tapped holes on the motor X-adapter. Also I suspect you have a possible bolts-vibrating-out problem since you can't really tighten them without making the grommets obsolete. Fun fun.
Comment by Marooned on June 4, 2012 at 7:54am
I can't see a hole in the middle. So how do you mount there common outrunners which has shaft on one side and propeller mounting attached on the opposite side?
JDrones
Comment by Jani Hirvinen on June 4, 2012 at 7:58am
Tsahi, you should able to use those on 13mm arms too as.
Sergei, nope. You can tighten screws tight as there is lock insert inside grommets. Insert won't allow you to crush your grommets.
Comment by Todd Hill on June 4, 2012 at 8:53am
Nice work Jani, Square and round! Best all around universal mount I have seen yet.
Comment by Vernon Barry on June 4, 2012 at 9:05am
@Marooned, you use the inlcuded mount with the hole that came with the motor, and then that attaches to this mount. Hopefully you saved those parts that came in the bag with every motor.
Comment by Marooned on June 4, 2012 at 9:39am
Ok, maybe I'm missing something but can't image how to mount a motor like that. Anyway, the design is beautiful. Good job :)
Comment by Alex Lee on June 4, 2012 at 9:59am
Now if I could just order more of the x adapters. I bent all mine and therefore bolted the can to the arm..
I'm looking for x adapters for the "heavy" motors sold on the various drones sites. 2836/9 880kv.
any chance you could make square plates that I could just bolt the motor to and then bolt to this. the alu x is very bendable.
Comment
